A-100 DIY Kit#1
2007-04-19 by ludu ludu
Is there any release date for the A-100 DIY Kit #1 ? I check every day thomann.de ! Can't wait ! Chers Ludu
2007-04-20 by hardware@doepfer.de
Ludu, the DIY kits #1 are already in stock but the user's manual is not yet finished. The manual will describe how to wire the DIY PSU with the bus boards and the external transformer. And it will include some suggestions for building your own case e.g. from wood (with measures for some examples). Though the wiring is very simple the manual has to be finished before we offer the kit officially. Even the mix expander module (A-138x) is now available - so far only with unlabelled front panel as we are not sure which type of front panel the users prefer. Best wishes Dieter Doepfer
> -----Ursprüngliche Nachricht----- > Von: Doepfer_a100@yahoogroups.com > [mailto:Doepfer_a100@yahoogroups.com]Im Auftrag von ludu ludu > Gesendet: Freitag, 20. April 2007 00:00 > An: Doepfer_a100@yahoogroups.com > Betreff: [Doepfer_a100] A-100 DIY Kit#1 > > > Is there any release date for the A-100 DIY Kit #1 ? > I check every day thomann.de ! > > Can't wait ! > > Chers > Ludu
2007-04-20 by dingfutzer
Hi Group: Has anyone found a U.S. supplier for the appropriate transformer for the power supply? Initial description of this product did not include the struts and nut strips. Will the power supply and bus boards be available without these parts? My application is wider than 84 HP. Also, what is the approximate delivery date to Analogue Haven? Thanks --- In Doepfer_a100@yahoogroups.com, <hardware@...> wrote: > > Ludu, > > the DIY kits #1 are already in stock but the user's manual is not yet > finished. The manual will describe how to wire the DIY PSU with the bus > boards and the external transformer. And it will include some suggestions > for building your own case e.g. from wood (with measures for some examples). > Though the wiring is very simple the manual has to be finished before we > offer the kit officially. > > Even the mix expander module (A-138x) is now available - so far only with > unlabelled front panel as we are not sure which type of front panel the
> users prefer. > > Best wishes > Dieter Doepfer > > > -----Ursprüngliche Nachricht----- > > Von: Doepfer_a100@yahoogroups.com > > [mailto:Doepfer_a100@yahoogroups.com]Im Auftrag von ludu ludu > > Gesendet: Freitag, 20. April 2007 00:00 > > An: Doepfer_a100@yahoogroups.com > > Betreff: [Doepfer_a100] A-100 DIY Kit#1 > > > > > > Is there any release date for the A-100 DIY Kit #1 ? > > I check every day thomann.de ! > > > > Can't wait ! > > > > Chers > > Ludu >
2007-04-23 by hardware@doepfer.de
> Hi Group: Has anyone found a U.S. supplier for the appropriate > transformer for the power supply? Initial description of this product > did not include the struts and nut strips. Will the power supply and bus > boards be available without these parts? Even the single parts will be available (e.g. the DIY power supply only without bus boards, without the external transformer and without the threaded metal strips. > My application is wider than 84 HP. You can mount the strips side by side and even cut the strips with a metal saw if the width is not a multiple of 84 HP. The strips are made from 1.5 mm steel. > Also, what is the approximate delivery date to Analogue Haven? Please contact Analogue Haven. As far as I know they have not yet pre-ordered the DIY kits. Best wishes Dieter Doepfer
2007-05-01 by ludu ludu
Thank you Dieter, I see an user's manual here ( http://www.doepfer.de/a100_man/A100_DIY_case.pdf) so I suppose you are ready to ship this DIY kit via thomann.de, isn't it ? Best, ludu On 4/20/07, hardware@doepfer.de <hardware@doepfer.de> wrote: > > Ludu, > > the DIY kits #1 are already in stock but the user's manual is not yet > finished. The manual will describe how to wire the DIY PSU with the bus > boards and the external transformer. And it will include some suggestions > for building your own case e.g. from wood (with measures for some > examples). > Though the wiring is very simple the manual has to be finished before we > offer the kit officially. > > Even the mix expander module (A-138x) is now available - so far only with > unlabelled front panel as we are not sure which type of front panel the > users prefer. > > Best wishes > Dieter Doepfer > > > -----Ursprüngliche Nachricht----- > > Von: Doepfer_a100@yahoogroups.com <Doepfer_a100%40yahoogroups.com> > > [mailto:Doepfer_a100@yahoogroups.com <Doepfer_a100%40yahoogroups.com>]Im > Auftrag von ludu ludu > > Gesendet: Freitag, 20. April 2007 00:00 > > An: Doepfer_a100@yahoogroups.com <Doepfer_a100%40yahoogroups.com> > > Betreff: [Doepfer_a100] A-100 DIY Kit#1 > > > > > > > Is there any release date for the A-100 DIY Kit #1 ? > > I check every day thomann.de ! > > > > Can't wait ! > > > > Chers > > Ludu > > > [Non-text portions of this message have been removed]
2007-05-02 by hardware@doepfer.de
Yes, the A-100 DIY kits #1 are ready to ship. Even the manual is ready now. DIY kits #2 will be available about end of May. Best wishes Dieter Doepfer > -----Ursprüngliche Nachricht----- > Von: Doepfer_a100@yahoogroups.com > [mailto:Doepfer_a100@yahoogroups.com]Im Auftrag von ludu ludu > Gesendet: Dienstag, 1. Mai 2007 10:17 > An: Doepfer_a100@yahoogroups.com > Betreff: Re: [Doepfer_a100] A-100 DIY Kit#1 > > > Thank you Dieter, > > I see an user's manual here ( > http://www.doepfer.de/a100_man/A100_DIY_case.pdf) so I suppose > you are ready > to ship this DIY kit via thomann.de, isn't it ? > > Best, > ludu > > On 4/20/07, hardware@doepfer.de <hardware@doepfer.de> wrote: > > > > Ludu, > > > > the DIY kits #1 are already in stock but the user's manual is not yet > > finished. The manual will describe how to wire the DIY PSU with the bus > > boards and the external transformer. And it will include some suggestions > > for building your own case e.g. from wood (with measures for some examples). > > Though the wiring is very simple the manual has to be finished before we > > offer the kit officially. > > > > Even the mix expander module (A-138x) is now available - so far only with
> > unlabelled front panel as we are not sure which type of front panel the > > users prefer. > > > > Best wishes > > Dieter Doepfer > > > > > -----Ursprüngliche Nachricht----- > > > Von: Doepfer_a100@yahoogroups.com <Doepfer_a100%40yahoogroups.com> > > > [mailto:Doepfer_a100@yahoogroups.com > <Doepfer_a100%40yahoogroups.com>]Im > > Auftrag von ludu ludu > > > Gesendet: Freitag, 20. April 2007 00:00 > > > An: Doepfer_a100@yahoogroups.com <Doepfer_a100%40yahoogroups.com> > > > Betreff: [Doepfer_a100] A-100 DIY Kit#1 > > > > > > > > > > > Is there any release date for the A-100 DIY Kit #1 ? > > > I check every day thomann.de ! > > > > > > Can't wait ! > > > > > > Chers > > > Ludu > > > > > > > > [Non-text portions of this message have been removed] > > >
2007-05-02 by Silas Johansen
I can't find the DIY kit on the price list, neither on the Doepfer site or on Thomann.de - I'm going to need one of these very soon as I've just ordered an A-155 from Thomann and I'll have to remove my fixed filter bank and one standard width module to fit it in my current system. Naturally, I want to put those back in the case ASAP (probably meaning start of June when the next paycheck comes in). Thanks, /Silas On 5/2/07, hardware@doepfer.de <hardware@doepfer.de> wrote: > > Yes, the A-100 DIY kits #1 are ready to ship. Even the manual is ready > now. > DIY kits #2 will be available about end of May. > > Best wishes > Dieter Doepfer > > > -----Ursprüngliche Nachricht----- > > Von: Doepfer_a100@yahoogroups.com <Doepfer_a100%40yahoogroups.com> > > [mailto:Doepfer_a100@yahoogroups.com <Doepfer_a100%40yahoogroups.com>]Im > Auftrag von ludu ludu > > Gesendet: Dienstag, 1. Mai 2007 10:17 > > An: Doepfer_a100@yahoogroups.com <Doepfer_a100%40yahoogroups.com> > > Betreff: Re: [Doepfer_a100] A-100 DIY Kit#1 > > > > > > > Thank you Dieter, > > > > I see an user's manual here ( > > http://www.doepfer.de/a100_man/A100_DIY_case.pdf) so I suppose > > you are ready > > to ship this DIY kit via thomann.de, isn't it ? > > > > Best, > > ludu > > > > On 4/20/07, hardware@doepfer.de <hardware%40doepfer.de> < > hardware@doepfer.de <hardware%40doepfer.de>> wrote: > > > > > > Ludu, > > > > > > the DIY kits #1 are already in stock but the user's manual is not yet > > > finished. The manual will describe how to wire the DIY PSU with the > bus > > > boards and the external transformer. And it will include some > suggestions > > > for building your own case e.g. from wood (with measures for some > examples). > > > Though the wiring is very simple the manual has to be finished before > we > > > offer the kit officially. > > > > > > Even the mix expander module (A-138x) is now available - so far only > with > > > unlabelled front panel as we are not sure which type of front panel > the > > > users prefer. > > > > > > Best wishes > > > Dieter Doepfer > > > > > > > -----Ursprüngliche Nachricht----- > > > > Von: Doepfer_a100@yahoogroups.com <Doepfer_a100%40yahoogroups.com><Doepfer_a100%40yahoogroups.com> > > > > [mailto:Doepfer_a100@yahoogroups.com<Doepfer_a100%40yahoogroups.com> > > <Doepfer_a100%40yahoogroups.com>]Im > > > Auftrag von ludu ludu > > > > Gesendet: Freitag, 20. April 2007 00:00 > > > > An: Doepfer_a100@yahoogroups.com <Doepfer_a100%40yahoogroups.com><Doepfer_a100%40yahoogroups.com> > > > > Betreff: [Doepfer_a100] A-100 DIY Kit#1 > > > > > > > > > > > > > > > Is there any release date for the A-100 DIY Kit #1 ? > > > > I check every day thomann.de ! > > > > > > > > Can't wait ! > > > > > > > > Chers > > > > Ludu > > > > > > > > > > > > > [Non-text portions of this message have been removed] > > > > > > > > > [Non-text portions of this message have been removed]
> I can't find the DIY kit on the price list, neither on the Doepfer site or > on Thomann.de - I'm going to need one of these very soon as I've just > ordered an A-155 from Thomann and I'll have to remove my fixed filter bank > and one standard width module to fit it in my current system. Naturally, I > want to put those back in the case ASAP (probably meaning start > of June when the next paycheck comes in). The new products are not yet included in the normal price list (e.g. A-100 DIY kits, new modules, CV/Gate keyboard, Wheel Electronic, USB64). You find the prices of new or announced products on the news page of our website (where the product is described in short form) or on the individual information page of the product provided that such an individual page is already available. Best wishes Dieter Doepfer
