Doepfer
How to make the A-156 Hz/V
2007-05-05 by vliesgaard
Hello,
I have an Korg 800DV and I would like to sequence it with the
A-154/155/156 combo. But the A-156 only outputs V/Oct.
So how can you change the V/Oct signal into a Hz/V signal?
Thanks in advance Dirk.
103 TB 303 filter
2007-05-05 by amnesia
Hi all
I cant get access to the A103 TB FILTER, just interested to know how
accurate the sound is to the TB filter???
Ross
Re: [Doepfer_a100] 103 TB 303 filter
2007-05-06 by P. Hendricks
On 5/5/07 4:50 PM, "amnesia" <amnesia@internode.on.net> wrote:
> Hi all
Ross,
did you see this review from Chris Carter in your search?
http://www.soundonsound.com/sos/dec03/articles/doepfermodules.htm
hmmm... doesn't seem like he knew what is was supposed to be doing. But,
alas, haven't tried one. And didn't look like Ingo had samples either, not
that i want a clone, but also curious about this one.
-phil
AW: [Doepfer_a100] How to make the A-156 Hz/V
2007-05-07 by hardware@doepfer.de
> Hello,
So far there is no solution available within the A-100 to obtain quantized
Hz/V control voltages. The planned universal AD/DA module will probably
include a V/Oct -> Hz/V converter. But so far we have no planned release
date for this module. I'm not if there are other suitable converters
available.
Best wishes
Dieter Doepfer
Re: How to make the A-156 Hz/V
2007-05-07 by vliesgaard
--- In Doepfer_a100@yahoogroups.com, <hardware@...> wrote:
> > Hello,
quantized
> available.
> Best wishes
> Dieter Doepfer
The AD/DA converter is on my wich list. It looks to me like a realy
cool module.
But can't the Hz/V to V/Oct be done with something like a lin to log
transformer or lin to exp transformer?
Re: [Doepfer_a100] Re: How to make the A-156 Hz/V
2007-05-07 by Florian Anwander
Hi vliesgaard
I tried this, but not with satisfying results (Hz->Oct is critical for
the bottom end; Oct->Hz is critical at the upper end)
Florian.
AW: [Doepfer_a100] Re: How to make the A-156 Hz/V
> cool module.
Yes, but such a circuit would require the same costly matched transistor
pair with temperature compensation/regulation as used in VCOs but with the
opposite function. We do not plan such a module as it is not required within
the A-100 and I do not expect reasonable quantities for such a module.
Best wishes
Dieter Doepfer
