Doepfer
Re: [Doepfer_a100] First modular system?
2007-05-06 by Silas Johansen
Hi Pete,
If that's what you want you might want to consider getting rid of the Clock
Divider + Clock Sequencer, which would leave room for one more 8HP module.
Other modules to consider replacing are the ring mod (some people rarely or
never use those anyway), the S&H (same thing) and one of the mixers (the
VCA's have two inputs, and so may serve as mini-mixers). The space saved
could be used for other interesting modules - I'd probably go for a BBD or
Sampler/Wavetable OSC but other modules may be more interesting for you. If
you end up with 4HP left, consider getting an extra multiple - boring, but
handy, or maybe a VC switch
I'd replace both LFO's, one with an LFO2 and one with a VC-LFO. You may want
to replace the Low pass filter with one of the other filters in the A-100
series.
You could also mix in some Analogue Solutions/Systems modules - I believe
the A. Solutions modules use the same power connector as the Doepfer
modules, so those would fit easily.
But in the end it all comes down to what you want - that's the cool thing
about modulars. (Besides the patchability, extensibility and general
coolness factors ;)
Hope this is helpful,
Silas
On 5/6/07, Peter Marshall <peter.marshall3@btinternet.com> wrote:
>   Hi Doug,
> Thanks for the reply. I'm looking for that classic analogue sound in the
> first instance but definitely want to experiment, which is why I'm
> interested in taking modular route really, rather than simply buy a fixed
> synth.
> I'm a total novice when it comes to electronics though, so wouldn't dare
> attempt to build my own modules, for fear of burning the house down! ;)
> I think I'd primarily use a MIDI interface to control the synth, either
> with
> a keyboard controller or a computer based sequencer.
> I have read elsewhere that waiting times can be quite lengthy, is this
> something to expect in general or mainly for newly released modules?
> Thanks for the heads up on the Analogue Heaven list, I just signed up! :-)
> Regards,
> Pete
RE: [Doepfer_a100] First modular system?
2007-05-07 by Peter Marshall
Hi Silas,
Very helpful thanks! I've heard some demos of the BBD module in use and had
decided that I would probably get one in the future, but now I'm thinking
why wait? Looks like I've got plenty more research to do before I settle on
my first system, so thanks for all the pointers, I'll definitely be checking
them out.
Pete
  _____
From: Doepfer_a100@yahoogroups.com [mailto:Doepfer_a100@yahoogroups.com] On
Behalf Of Silas Johansen
Sent: 06 May 2007 23:14
Subject: Re: [Doepfer_a100] First modular system?
Hi Pete,
series.
coolness factors ;)
Silas
