Re: AW: [Doepfer_a100] a-110 lin fm mod and sync question -
2007-05-08 by davevosh@aol.com
In a message dated 5/8/2007 11:04:30 AM Pacific Daylight Time, hardware@doepfer.de writes: sorry for the late reply - but I had to understand the A-110 softsync circuit before I answer. The attenuator at the optional softsync input does make sense. As you probably know the A-110 has a sawtooth core. The comparator that triggers the discharge (or reset) of the sawtooth has normally a trigger threshold of 0V/GND. With the optional softsync the trigger level of the comparator can be modulated with an external signal. Different levels of the same soft sync signal lead to different results as the trigger threshold of the reset comparator is modulated with different amplitudes dear mr. doepfer, thanks for the soft sync info - i`ll have to consider adding it in the future - best, dave ************************************** See what's free at http://www.aol.com. [Non-text portions of this message have been removed]
