A-192 cv-midi converter comments? res.?
2007-05-10 by redsawcloud
Is the resolution of the A-192 cv-midi converter pretty smooth? If controlling something like a software filter cutoff point, would there be zippering? I read somewhere in this forum that it is not smooth enough to control pitch and that a higher resolution would be needed. I'm just looking for an idea of what applications users find it excels in. Does anyone use it to control plug-ins? Has it been discontinued? Thanks, Adrian
2007-05-10 by James Husted
Going from CV to MIDI will almost always have some sort of zippering effects. This is the nature of most MIDI continuous controller (CC) messages. The CV will always be converted to discrete MIDI steps and the only methods to make the steps small enough not to be easily noticed is to use pitch-bend commands or other MIDI CC commands that use higher and lower significant bits schemes. Most of the common MIDI commands (like pitch and volume) have only 128 steps for their complete range. In the pitch department these are usually notes and not the "spaces" between. Another method is to send Sys-Ex data but that is device dependent. A quote from the A-192 owners manual confirms this: The 16 analog inputs are internally converted into digital data by means of an 8-bit analog-to-digital converter (ADC). Because of the MIDI data format only 7 bits are used (MIDI data range 0...127). This means 128 steps. If your filters input is scaled with this in mind - not driving the full range of the filter for instance - you may be able mask the steps. Much depends on the MIDI controlled device. All control via MIDI and all CV to MIDI controllers have to deal with this problem. It is not unique to the A-192. -JH
On May 10, 2007, at 12:36 PM, redsawcloud wrote: > Is the resolution of the A-192 cv-midi converter pretty smooth? If > controlling something > like a software filter cutoff point, would there be zippering? I > read somewhere in this > forum that it is not smooth enough to control pitch and that a > higher resolution would be > needed. I'm just looking for an idea of what applications users > find it excels in. Does > anyone use it to control plug-ins? Has it been discontinued? > > Thanks, Adrian > > > > > Yahoo! Groups Links > > >
