Various A-100 Modules & Rack Effects FS/FT
2007-05-14 by dingfutzer
DOD R-845 Analog Spring Reverb - Very metallic sounding unit. One knob cap missing - $95 DOD R-880 Analog BBD Dual Delay Powered by (2) MN 3005 BBD chips - $135 Electra EP-550 12 Bit Delay Early digital unit has a sound that comes very close to analog BBD and tape delays. A few bars on the LED have burned out. Scarce device - $185 PAiA Tubehead Single rackspace (2) channel analog preamp Clean sounding well-built kit with power supply - $125 Loft 450 Analog Delay - This scarce device is operating properly, comes with the manual and original box and is unused new/old stock - $295 Tapco 4400 Dual Spring Reverb (2) channel analog spring reverb. Case sides machine cut & redrilled for flush faceplate - $195 12 Space 12" deep ATA Rack Case - ABS laminated 1/4" thick plywood with all recessed hardware, machine riveted aluminum, steel corners and threaded rails. Like new - $50 Doepfer A100: A101-2 LPG - $95 A114 Ring Mod - $70 A118 Noise/Random - $65, A121 Multimode VCF - $125, A144 Morph Controller - $65, A160 Clock Divider - $58, A161 Clock Seq. - $58, Analogue Systems RS110 Multimode VCF w/A100 adapter $140 Will trade for other euro synth modules. Please contact off-list and Thanks for the bandwidth, Bill [Non-text portions of this message have been removed]
