Doepfer
Some A-121 issues
Some A-121 issues
2007-05-30 by Michael Wagner
I've noticed a few things with my A-121 Multimode Filter. I hope
someone can clarify, wether this is normal behaviour or not. (I think
I already posted the first issue once, but unfortunately I never got a
reply...)
1. In direct comparison with the A-105 SSM Filter, the output level is
about 20 dB lower. I set the input levels of both filters to a level,
where the signal is at the maximum level without any distortion (which
is about half way up on the A-105 and somewhere slightly below the
maximum input level on the A-121)
2. At low(est) fc settings, the highpass sounds like it is filtering
high frequency(!) components from the signal. I don't assume, that
this is normal behaviour, or is it?
Furthermore: With fc at maximum, I still hear the signal. Is there a
way to increase the range, so that at the highest fc setting, the
signal is inaudible?
3. The notch-filter seems to behave simliarly to the highpass, in that
it seems to filter high frequencies, when fc is set low.
Are these three points common problems, that are explained in the way
the module is built, or is my A-121 simply defective?
I'd be grateful for any clarifying reply.
-Michael
Re: [Doepfer_a100] Some A-121 issues
2007-05-30 by Florian Anwander
Hi Michael
The A-105 has incredible power in comparison to all other A-100 filters,
it is my absolute favourite A-100 filter. The A-121 could be driven with
more input signal power (you might reduce the inputresistor after the
gain potentiometer).
Yes. This is mentioned already in the Datasheet of the Curtis Chip.
There is a modification which traps into more inconvenient resonance
behaviour.
I tried it once, but took it back, because I did not like the resonance
thing.
Might be trimmable. Don't have the schemoes here. Maybe you have to
weigh up against how low the filter goes on the low end (you might run
into the samething with the lowpass filter setting on the low end).
Yes. Know behaviour as above
Your  module in general works as it can and should do. Topic 2 might be
a question of trimming (I cannot judge from here).
Florian
2007-06-01 by Michael Wagner
Thanks a lot for your informative reply, Florian. These issues didn't
bother me very much, but I still wanted to know wether this was
normal.
-Michael
