Doepfer
Filter Suggestion
Filter Suggestion
2007-06-02 by mss_panzer
So when might we be able to see a Polivoks VCF?  Perhaps based on the A-
124 design, with a HP/LP mix potentiometer and a solo BP pot?
Anybody have any thoughts on this?
Re: Filter Suggestion
2007-06-02 by ilanode
If DIY is an option:
http://m.bareille.free.fr/modular1/vcf_polivoks/vcf_polivoks.htm
Rgds, Ingo
AW: [Doepfer_a100] Filter Suggestion
2007-06-04 by hardware@doepfer.de
We designed a Polivoks filter about one year ago but we stopped the project
as Shawn Cleary of Analogue Haven informed us that such a filter is under
development by the Polivoks inventor Vladimir Kuzmin. It should be available
soon from Analogue Haven.
Best wishes
Dieter Doepfer
> [mailto:Doepfer_a100@yahoogroups.com]Im Auftrag von mss_panzer
> Gesendet: Samstag, 2. Juni 2007 22:27
> Betreff: [Doepfer_a100] Filter Suggestion
2007-06-04 by Tim Stinchcombe
There is nothing particularly special about the design, it is simply
one of the standard state-variable configurations, albeit using the
inherent integrator action of a (compensated) op amp - it is to be
found in at least one of the filter books that I have. The only
real 'novelty' aspect in the Polivoks appears to be the use
of 'programmable' op amps to provide a variable cut-off frequency. It
should be relatively simple to add another op amp in order to make
the high-pass output available, and the method of setting the current
which 'programs' the op amps could possibly be improved, as the
transistor-resistor set-up is dealing with some pretty small currents
(nano-amps), and I dare say is very sensistive to differences in
individual components, perhaps making initial set-up tricky (but this
is pure conjecture, I've not tried actually breadboarding the circuit
to find out).
Tim
project
under
available
> Best wishes
> Dieter Doepfer
the A-
2007-06-07 by mss_panzer
I appreciate everyone's suggestions thus far.  Time to find my solder.
--- In Doepfer_a100@yahoogroups.com, "Tim Stinchcombe" <timothy@...>
simply
It
current
currents
this
circuit
> to find out).
> Tim
> project
is
> under
be
> available
> > Best wishes
> > Dieter Doepfer
on
> the A-
