Doepfer
A-121 Multimode Filter behaviour
2002-04-03 by mdimmm
Dear list members,
I was under the impression that a high pass filter should let a
signal pass almost unchanged with the cut-off frequency all the
way down (the opposite of a low pass). However my A-121
seems to be cutting higher frequencies at low cut-off settings
(resonance all the way down), more like a band pass filter.
The result is especially clear when runnig a rich external signal
through it, songs on the radio in my case.
When viewing an A-121's sine wave output on an oscilloscope,
the "Band" output seems to be the only output to generate a true
sine wave. The waveforms from "High" and "Low" seem to be
clipped at the highest and lowest points, respectively, and the
"Notch" output is significantly lower than the others.
Is this an anomaly of my module or do all A-121's behave like
this?
And which of the 4 lengths of cables available for the A-100 are
the white ones?
Thanks
M. Dimm
Re: A-121 Multimode Filter behaviour
2002-04-04 by stinchcombe_t
Hi M. Dimm
My A-121 behaves pretty much as you describe it: all the little odd
things you mention are almost certainly due to the CEM3320 VCF chip
that does all the work. The datasheet for the 3320 mentions (for
self-oscillation) that 'the sinewave is not clipped by the first
stage', so this would seem to equate to the  bandpass output in the
A-121 configuration - if one wants to use the filter as an oscillator,
then this is clearly the best place to take the output from (unless of
course the distortion is desired!).
The problem of the highpass output (with a low cut-off frequency)
acting more like a bandpass filter, whilst annoying, is also likely to
be a limitation within the chip. The chip contains 4 'gain cells'
which act in a similar manner to VCAs, and are connected together with
various resistors and capacitors to give the filtering action. The
gain setting is used to control the filter cut-off frequency, and the
gain they can provide probably decreases as the input frequency
increases. Thus for a low cut-off frequency, their gain is already set
quite low: passing high frequencies through them will decrease the
gain further, and thus higher frequencies get attenuated. Standard op
amps (the staple component in most modules) also behave like this, and
in fact the 'emphasis' filter in the A-199 reverb module appears to
make good use of this effect - it is really a high pass filter, turned
into a bandpass one by the falling gain available from the op amp as
the frequency increases. I don't have an A-123 high pass module, but I
note that it uses the same CEM 3320 chip - it would be interesting to
hear from other list members whether it behaves in a similar fashion.
This probably isn't much consolation to you, merely confirming that
you are stuck with this behaviour! (Can't help with the white patch
cord length!)
Tim
[The views expressed above are entirely those of the writer and do not
represent the views, policy or understanding of any other person or
official body.]
> this?
> the white ones?
> Thanks
> M. Dimm
Re: [Doepfer_a100] Re: A-121 Multimode Filter behaviour
2002-04-04 by Florian Anwander
Hi Tim
There is a modification that gives a much better highpass behaviour at low
cutoff frequencies to the A-121. I don't know whether it is documented in
the service manual. But this may cause a uncontrolled and unwanted self
oscillation in high cutoff frequencies.
No. As far I understood the problem appears only in the state-variable
circuit. And the 123 is a pute pure hipass filter.
Florian
Florian Anwander                  |ConSol*  HP-Support
Tel.   +49.89.45841-133           |Consulting&Solutions Software GmbH
Fax    +49.89.45841-139           |Franziskanerstr. 38, D-81669 München
email: florian.anwander@consol.de |http://www.consol.de
Hi Florian,
at low
documented in
Thanks, that's interesting to know. The service manual potentially
contains much useful info, but the price rather puts me off!!
This is also nice to know, thanks again!
Tim
official body.]
2002-04-04 by bakis Sirros
hi,
you mean the grey cables lenght??
they are 30cm.there are no white cables from doepfer.
bakis.
--- stinchcombe_t <tstinchcombe@qinetiq.com> wrote:
> Hi M. Dimm
> the little odd
> CEM3320 VCF chip
> mentions (for
> by the first
> as an oscillator,
> cut-off frequency)
> is also likely to
> 'gain cells'
> frequency, and the
> input frequency
> gain is already set
> will decrease the
> module appears to
> pass filter, turned
> from the op amp as
> pass module, but I
> be interesting to
> similar fashion.
> confirming that
> the white patch
> cord length!)
> Tim
> writer and do not
> other person or
> official body.]
> should let a
> frequency all the
> A-121
> cut-off settings
> pass filter.
> external signal
> oscilloscope,
> generate a true
> seem to be
> others.
> behave like
> > this?
> the A-100 are
> > the white ones?
> > Thanks
> > M. Dimm
synthfreak(parallel worlds)
athens-greece
[Doepfer_a100] group owner-moderator
Do You Yahoo!?
Yahoo! Tax Center - online filing with TurboTax
http://taxes.yahoo.com/
oops!!!!!wrong....the grey cables are 50cm long.
sorry,
bakis.
> Hi M. Dimm
> the little odd
> CEM3320 VCF chip
> mentions (for
> by the first
> as an oscillator,
> cut-off frequency)
> is also likely to
> 'gain cells'
> frequency, and the
> input frequency
> gain is already set
> will decrease the
> module appears to
> pass filter, turned
> from the op amp as
> pass module, but I
> be interesting to
> similar fashion.
> confirming that
> the white patch
> cord length!)
> Tim
> writer and do not
> other person or
> official body.]
> should let a
> frequency all the
> A-121
> cut-off settings
> pass filter.
> external signal
> oscilloscope,
> generate a true
> seem to be
> others.
> behave like
> > this?
> the A-100 are
> > the white ones?
> > Thanks
> > M. Dimm
athens-greece
Do You Yahoo!?
2002-04-08 by mdimmm
--- In Doepfer_a100@y..., Florian Anwander <
Florian.Anwander@c...> wrote:
> Hi Tim
behaviour at low
documented in
unwanted self
interesting to
fashion.
variable
> Florian
That was going to be my next question, whether the A-123 has
the same characteristics.
I'd be interested to know more about that modification to the A-
121 though.
Thanks to all for the extensive information.
M. Dimm.
2002-04-09 by Florian Anwander
Dear mdimmm
> I'd be interested to know more about that modification to the A-121 though.
I'll have a look at the Service manual at home
Florian
2002-04-09 by stinchcombe_t
Hi M Dimm
> interesting to
> fashion.
> variable
The above is no longer true! I treated myself to some new modules last
week, including the A-123.  My initial reaction is that the A-123
behaves in pretty much the same fashion as the A-121, and in fact
could be slightly worse. I haven't really had time to check it out
properly though, I'll try and do so over the weekend, and then I'll
report back!
Tim
official body.]
Hi Tim
> report back!
Uuups, I just remember, that my A123 is one of those modules with a
preseries frontplate, but should be electronically the same as the series
modules (some parts soldered on the other side). I cannot confirm that it
is REALLY a electronically identical. Also I have to look.
Florian
2002-04-10 by stinchcombe_t
I can happily report that the A-123 is in fact *considerably better*
than the A-121 in this respect! (For my initial 'look-see'  I used an
A-110, but since the sine wave is quite 'approximate', it gets badly
mangled by the filter, which tends to obscure things a bit! The sine
output of my A-111 is clearly much closer to a pure tone, and thus
comes through the filter less mangled, so it's easier to see what is
going on.) By setting the VCO to a specific frequency and monitoring
the voltage levels out of the filters, I adjusted the frequency
setting on the filter so that the given frequency was the -3dB lower
cut-off frequency, then I increased the VCO frequency until I went
through the passband and came to the upper -3dB point. (I had
resonance set to minimum throughout.) In all cases I tried, regardless
of the Freq knob setting, the A-123 upper frequency is at about 30kHz:
for the A-121 it was as follows:
Lower cut-off freq = 25Hz (approx F=2.5 on 121, F=2 on 123), upper
cut-off = 800Hz
lower = 50Hz (F=3.5 &F=3), upper = 1.6kHz
lower = 100Hz (F=4.5 & F=3.5), upper = 3.3kHz
lower = 200Hz (F=5 &F=4.5), upper = 6.6kHz
lower = 400Hz (F=5.5 & F=5), upper = 11.5kHz
Setting the A-121 to give the upper cut-off at 15kHz, gives the lower
as 600Hz, at F=6. At low F settings, 0 - 2, on the A-121 there comes a
point where you don't really get a well defined passband at all! This
clearly supports M Dimm's findings, i.e. that the A-121 high pass is
really more bandpass, especially at low F knob settings!
The intro paragraph to the high pass chapter of Don Lancaster's
'Active Filter Cookbook' puts this problem rather bluntly: "In
reality, there is no such thing as an active high-pass filter, for the
upper-frequency rolloff of the operational amplifiers in use will
combine to give a passband. If an active filter is to be good for
anything, we have to save enough 'daylight' between the lower passband
limit of the active circuit and the upper limit set by the op amp."
The A-123 obviously achieves this, the A-121 less so. Haven't managed
to fathom out why the A-121 configuration should be so much worse, and
unfortunately there is unlikely to be enough info on the CEM datasheet
to be able to work it out, so its likely to remain a mystery to me
(unless Dieter is reading and can offer some explanation....)
Tim
official body.]
