Doepfer
Where can I get Doepfer 3U (a100g3) side plates in the US? Can I make them?
2007-06-22 by aidisym0
I was planning to buy an a100g3, as I only want a few Euro models and have very limited
space in my rig... but I had to buy an a100g6 case as the 3U one wasn't available.
The only difference seems to be side plates... the 6U model has 2x 6U side plates... so
theoretically if I got 4x 3U sideplates I could split the rails into two built frames, right?
or even for now, just get 2x 3U sideplates, as I won't utilize the other set of rails for a
while, if ever.
I don't really have access to any metal shops where I could cut metal myself..
Do I have any easy options other than building them myself? I figure I could just measure
the 6U plate's dimensions, and order 2 custom cut sidepanels from
http://www.metalsdepot.com/products/alum2.phtml?page=plate&LimAcc=%20&aident=
then drill the holes myself. There shouldn't be any problem with grounding, right? Maybe
the hole drilling isn't quite as simple as I'm making it out to be - I've yet to get the rack or
see how the rails mount
Is it worth trying to go through Proma overseas?
Thoughts?
Chris
AW: [Doepfer_a100] Where can I get Doepfer 3U (a100g3) side plates in the US? Can I make them?
2007-06-22 by hardware@doepfer.de
plates... so
Yes, but you also need the top/bottom covers, a second power supply and
another back plate (those with the mains inlet/switch/fuse holder) to obtain
two complete A-100G3
could just measure
I'd recommend to apply the removed 6U side plate to the new one. Then you
have an exact reference for the positions of the holes. I think the bigger
problem is to get the aluminium panel in the right dimensions. Dimensional
drawings are available on ProMa's website.
Look at ProMa's website. They also have representatives in other countries.
As we obtain the A-100 frames ready built from our manufacturer (they order
the parts from ProMa, built the frames and add the custom made back panels,
power supply and bus boards) we do not have these parts in stock. That's why
we published the ProMa information so that customers can order directly from
ProMa.
Best wishes
Dieter Doepfer
