Doepfer
source for shorter 1/8" 3.5mm cables?
2007-06-30 by plastichorneddevil
Id like to get my hands on some more 6 inch or so patch cables, I have
my modules so closely arranged it would be a lot neater without two
feet of spaghetti hanging between adjacent modules. Thanks for any
help, Ive looked high and low.
kelly
Re: source for shorter 1/8" 3.5mm cables?
2007-07-07 by Stu Grimshaw
i could use not only shorter, but cloured cables, but haven't found anywhere on the net.
anyone know a source of coloured cables ?
cheers,
stu
--- In Doepfer_a100@yahoogroups.com, "plastichorneddevil" <kellyborkert@...> wrote:
> kelly
2007-07-30 by vcovcfvca
This may not help you, but I've just been making up a batch of my own
cables of various lengths in the following colours: Red, Green, blue,
Yellow, White. I was lucky enough to get an offcut of surplus RGB-HV
cable loom (computer/video people may know of this), which is
basically a plastic sheath containing 5 separate coloured cables.
Each cable within the sheath is a centre core copper conductor
surrounded by an insulator and then a braided wire shield with a
coloured plastic outer layer (ie: like a mini or narrow gauge coaxial
cable)- perfect for patch cables and highly durable as well. I'm very
happy with the results so far. They even "feel" good to patch! I
recommend it for anyone who can find a loom like this.
By the way, I'm new here so hello all!
Adam
--- In Doepfer_a100@yahoogroups.com, "Stu Grimshaw" <grimshaw@...>
> cheers,
> stu
have
two
any
> > kelly
2007-08-12 by ErnstKarel
This thread seems to have gone to sleep -- does this mean that nobody
knows of anyone selling pre-made short patch cables?  15 cm/ 6 inches
or even shorter would be great for the kind of clusters of utility
modules that I often end up using.
Any tips would be much appreciated!
-Ernst
AW: [Doepfer_a100] Re: source for shorter 1/8" 3.5mm cables?
2007-08-13 by hardware@doepfer.de
> -Ernst
If you are a bit familiar with soldering you can make such cables yourself.
The problem with industrial made cables is the minimum quantity. We have to
order a minimum of 1000 cables of each type from our manufacturer. If there
are sufficient inquiries we could add this length to our range of articles
but so far we had not many inquiries for shorter cables. The price will be
probably the same as for the 30 cm cables as the shorter cable has not much
influence (the connectors and working time remains the same).
Best wishes
Dieter Doepfer
Re: AW: [Doepfer_a100] Re: source for shorter 1/8" 3.5mm cables?
2007-08-13 by Doug Wellington
[WARNING: Shameless self-promo]
I recently received a shipment of almost 1300 patch cables in various
sizes and colors.  You can see more info about these cables at Larry's
old web site:
http://www.wiseguysynth.com/larry/cable/cable.htm
I should have my new Stooge Panels website live about September 1st,
and I'll have all of the cables inventoried and available for sale
then...
-Doug
http://www.analognotes.com
http://www.stoogepanels.com
Re: [Doepfer_a100] Re: source for shorter 1/8" 3.5mm cables?
2007-08-15 by Eyesaw
Hi Gabriel:
       Your modules were sent yesterday via US Mail. Hope you enjoy them. I will be putting some on eBay today so search Doepfer if your interested -
Bill
  Sent: Sunday, August 12, 2007 10:03 PM
  Subject: [Doepfer_a100] Re: source for shorter 1/8" 3.5mm cables?
  Hey there,
  Check up for chips for Brain on ebay, he sales cables like that and maybe you can ask him
  some special oders...
  cheers!
  g.
    avast! Antivirus: Inbound message clean.
    Virus Database (VPS): 000764-8, 08/12/2007
    Tested on: 8/13/2007 6:55:26 AM
    avast! - copyright (c) 1988-2007 ALWIL Software.
avast! Antivirus: Outbound message clean.
Virus Database (VPS): 000765-1, 08/13/2007
Tested on: 8/15/2007 10:15:19 AM
http://www.avast.com
Sorry Folks - meant to be private email
  Sent: Wednesday, August 15, 2007 10:15 AM
  Subject: Re: [Doepfer_a100] Re: source for shorter 1/8" 3.5mm cables?
  Hi Gabriel:
  Bill
  Hey there,
  cheers!
  g.
    Tested on: 8/15/2007 10:26:21 AM
Tested on: 8/15/2007 10:37:58 AM
2007-08-22 by gabu_004
Hi there,
Modules are recieved and working perfectly fine :D
Nice packaging and no custom fees :D:D
Thanks a lot!!!!!!!!!!!!!!!!!
g.
--- In Doepfer_a100@yahoogroups.com, "Eyesaw" <eyesaw@...> wrote:
> Hi Gabriel:
> Thanks,
> Bill
>   ----- Original Message -----
>   From: gabu_004
>   Hey there,
him
>   cheers!
>   g.
