Re: A-125 phase shifter impressions?
2008-01-07 by vcovcfvca
Cool, hope you enjoy it. I'm over in Australia and never get to try modules before buying, so generally find that I have to take a leap of faith. So far all modules I've bought have been useful/enjoyable in one way or another. The more modules I get, the more uses I find for my older modules. :0) --- In Doepfer_a100@yahoogroups.com, Ross Goniakowski <carfull@...> wrote: > > i'm going to find out for myself in a few days, i ordered one...the way you describe using it is pretty much what i had in mind ;) > > > ----- Original Message ---- > From: vcovcfvca <vcovcfvca@...> > To: Doepfer_a100@yahoogroups.com > Sent: Monday, January 7, 2008 3:39:02 PM > Subject: [Doepfer_a100] Re: A-125 phase shifter impressions? > > Even later response! > I just recieved the A-125 yesterday, so haven't had a chance to give > it a really good run yet, but on first listen it has given my modular > a nice additional sound shaping tool. Its sufficiently swooshy and > swirly when required, as all good phasers should be. Jet and wind > sounds are a "breeze"! Plus, I'm enjoying trying all of those wacky > modulated phase shifts that I could never do on an effect pedal. The > manual phase shift knob in conjunction with the CV amount knob allows > you to kind of dial in a frequency band within which your phase shift > occurs. Again, something that goes beyond the average pedal. > Modulating it with audio frequency CVs at high resonance yielded some > interesting results. Its not a module to use in every patch (eg: a > guitarist probably wouldn't play every note through a phaser pedal), > but a nice expansion module to experiment with. Soundwise, although I > quite like the resonant tone from the A-125, I would say its not > as "watery or coloured" (don't you love subjective sound > descriptions! !??) as the EH Small Stone (which I own). Its perhaps > closer to the Boss PH-1 (which I used to own). This would kind of make > sense from Mr. Doepfer's description of the circuit. I'm guessing this > also means that its likely to be close to the Sytsem 100 phase shifter > (which I've not used). I belive the EH Small Stone uses > transconductance op amps which yield a different resonant tone. > > On a final note: for me the A-125 was the right combination of price, > straight forward features and size (I like the fact that it only uses > 8HP in my rack). > > Hope this helps you and others. > > Regards, > Adam > > --- In Doepfer_a100@ yahoogroups. com, Florian Anwander > <Florian.Anwander@ ...> wrote: > > > > Hi Ross > > > > > i can't find any audio examples on the net..the only analog phase > shifters i've heard are the EH Small Stone and the MXR Phase 90, i'm > interested in at least as good quality ...i'm covered on the digital > end, but i want the ability to patch in to my Doepfer system, and > there are some used mods available atm... > > Late jump in: The A-125 can sound very similar to the EH small stone.
> > > > Florian > > > > > > > [Non-text portions of this message have been removed] >
