Doepfer
A-133 as VCA or 2 quadrant multiplier
2008-01-11 by nicholas.rejack@elf.mcgill.ca
Can I use A-133 as a 2-quadrant multiplier without adding an offset to
the VC? Obviously this is no problem for all + signals like most
envelopes, but how about for LFOs?  For example, to get a good vibrato,
I would have to run a sine into A138c and use the offset function to
get 0 amplitude at the maximum negative portion of the sine. Is there
any other module that does offsets like this?
-nicholas
AW: [Doepfer_a100] A-133 as VCA or 2 quadrant multiplier
2008-01-11 by hardware@doepfer.de
> -nicholas
The A-133 has a manual offset control. If you e.g. turn this control to ~ +3
you can add an LFO signal with adjustable level to the CV input.
In general nearly all A-100 modules have an offset control for each voltage
controlled parameter. There are only a few exceptions like the low-cost dual
VCA A-132-1 or the dual crossfader A-134-2 with small 4 HP front panels
(only sockets, no controls).
Best wishes
Dieter Doepfer
Re: AW: [Doepfer_a100] A-133 as VCA or 2 quadrant multiplier
So the man knob controls not only amount of multiplication (-2.5x at
knob setting of -5 to +2.5x at knob setting of +5) but also
adds/subtracts an offset?
-nicholas
Quoting hardware@doepfer.de:
>> -nicholas
> Best wishes
> Dieter Doepfer
AW: AW: [Doepfer_a100] A-133 as VCA or 2 quadrant multiplier
2008-01-12 by hardware@doepfer.de
> -nicholas
That's the same - unless you speak about a DC offset voltage appearing at
the output.
Best wishes
Dieter Doepfer
I'm not in the office from January 14-27,2008 as we exhibit at the NAMM show
in Anaheim/USA. During this time I cannot respond to emails. In case of
urgent technical questions please contact software@doepfer.de or
keyboards@doepfer.de.
