Doepfer
A-119 - not patched, but overloaded...
2008-01-11 by Chris Henkel
I just switched on my A-100-system and noticed (I am an complete newbie
regarding the A-100) on my A-119 (Ext. Input) that the 'Over Load' and the
'Thres.' LEDs are continuously on - with no patch-cables anywhere on the
rack, and regardless to the setting of the 'Gain' or 'Thres.' dials. Putting
signals onto 'Asym. In' or 'Symm. In' has no effect on the LEDs.
The only cables connected to the A-100 are power, and MIDI 'in' and 'out' on
both the A-192 and the A-112.
The biggest change I made recently to the system was adding a used (seems to
be pretty old!) A-146. I'll remove that and see if it helps - if not: what
might be wrong with the (new) A-119?
TIA.
chris henkel
Re: A-119 - not patched, but overloaded...
...ouch...sorry...never mind:
one of the nearby modules (which I removed to be able to plug in the A-146)
bus-plugs was a bit loose - putting it back onto the bus fixed the whole
rack...
Sorry for the noise...
chris henkel
2008/1/11, Chris Henkel <henkel.chris@googlemail.com>:
> to be pretty old!) A-146. I'll remove that and see if it helps - if not:
> what might be wrong with the (new) A-119?
