Cubase 3 SX > MAQ 16/3 > MOTU Microlist > Virus TI Plugin > Latency on live play
2008-02-20 by kloppe_andrew
I know the following is probably an issue with my overall setup -- currently having a quesiton with cubase discussion groups. Though i figure there most be some good midi expertise in this forum. Still i figure i ask this forum as well. ********************************** I'm experiencing delays with my Doepfer MAQ 16/3 during life play/recording. There is always a very slight delay of the MIDI signal from my [u]Doepfer sending midi[/u] signals [u]via the MOTU microlite[/u] to the [u]VST plug-in of my VIRUS TI [/u](delay is about 1/64 or so). When I record the doepfer sequence the midi actually gets recorded properly onto the midi track. Also when I replay these recordings they replay on my Virus TI exact. Seams there is some latency introduced when I play live and [u]route [/u]my midi signal [u]via my MIDI hub [/u]directly to the [u]Virus TI vst/plug-in.[/u] Also when I route that same Doepfer midi signal to, for example, any Reason instruments (Thor, etc.) it plays wwithout delay (whether live or recorded midi). I tried the entire routine of placing the >>>ignoreportfilter<<< in the cubase program folder (incl. disabling emulated ports),[u] at no avail.[/u] Any suggestion on how to resolve this midi latency? This slight delay effectively makes my Doepfer not usable. Cubase 3 XP SP.2 Doeopfer MAQ 16/3 Virus TI (via vst/plugin) MOTU Microlite Reason 4.0 Reaktor
