a155 Grooves
2008-02-23 by dab
2008-02-23 by dab
hello Group what methods you use to let the 155 play in swing or with a variable pattern groove ? for swing i found a clock synced triangle or saw down lfo extremely usefull, but i would like to archieve something more complex.
2008-02-23 by Silas Johansen
You can feed a VC-LFO from one row and get variable step lengths.
On Sat, Feb 23, 2008 at 3:53 PM, dab <trafo-dab@gmx.de> wrote: > hello Group > > > what methods you use to let the 155 play in swing or with a variable > pattern groove ? > for swing i found a clock synced triangle or saw down lfo extremely > usefull, > but i would like to archieve something more complex. > > > > > > > > Yahoo! Groups Links > > > >
2008-02-23 by dab
hello silas this sounds interesting, could you explain how it works ? i dont quite understand the patching. Silas Johansen schrieb: > > You can feed a VC-LFO from one row and get variable step lengths. > > On Sat, Feb 23, 2008 at 3:53 PM, dab <trafo-dab@gmx.de > <mailto:trafo-dab%40gmx.de>> wrote: > > hello Group > > > > > > what methods you use to let the 155 play in swing or with a variable > > pattern groove ? > > for swing i found a clock synced triangle or saw down lfo extremely > > usefull, > > but i would like to archieve something more complex. > > > > > > > > > > > > > > > > Yahoo! Groups Links > > > > > > > > > > > > __________ NOD32 2897 (20080222) Information __________ > > Diese E-Mail wurde vom NOD32 antivirus system geprüft > http://www.nod32.com [Non-text portions of this message have been removed]
CV out from one of the two CV rows on the A-155 to CV in on an A-147 voltage controlled LFO. Square out from the A-147 to clock in on A-155.
On Sat, Feb 23, 2008 at 8:17 PM, dab <trafo-dab@gmx.de> wrote: > > hello silas > > this sounds interesting, could you explain how it works ? > i dont quite understand the patching. > > Silas Johansen schrieb: > > > > > You can feed a VC-LFO from one row and get variable step lengths. > > > > On Sat, Feb 23, 2008 at 3:53 PM, dab <trafo-dab@gmx.de > > <mailto:trafo-dab%40gmx.de>> wrote: > > > hello Group > > > > > > > > > what methods you use to let the 155 play in swing or with a variable > > > pattern groove ? > > > for swing i found a clock synced triangle or saw down lfo extremely > > > usefull, > > > but i would like to archieve something more complex. > > > > > > > > > > > > > > > > > > > > > > > > Yahoo! Groups Links > > > > > > > > > > > > > > > > > > > > __________ NOD32 2897 (20080222) Information __________ > > > > Diese E-Mail wurde vom NOD32 antivirus system geprüft > > http://www.nod32.com > > > [Non-text portions of this message have been removed] > >
2008-02-23 by dab
Silas this was exactly what i was looking for, thank you very much. Silas Johansen schrieb: > > CV out from one of the two CV rows on the A-155 to CV in on an A-147 > voltage controlled LFO. Square out from the A-147 to clock in on > A-155. > > On Sat, Feb 23, 2008 at 8:17 PM, dab <trafo-dab@gmx.de > <mailto:trafo-dab%40gmx.de>> wrote: > > > > hello silas > > > > this sounds interesting, could you explain how it works ? > > i dont quite understand the patching. > > > > Silas Johansen schrieb: > > > > > > > > You can feed a VC-LFO from one row and get variable step lengths. > > > > > > On Sat, Feb 23, 2008 at 3:53 PM, dab <trafo-dab@gmx.de > <mailto:trafo-dab%40gmx.de> > > > <mailto:trafo-dab%40gmx.de>> wrote: > > > > hello Group > > > > > > > > > > > > what methods you use to let the 155 play in swing or with a variable > > > > pattern groove ? > > > > for swing i found a clock synced triangle or saw down lfo extremely > > > > usefull, > > > > but i would like to archieve something more complex. > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > Yahoo! Groups Links > > > > > > > > > > > > > > > > > > > > > > > > > > > > __________ NOD32 2897 (20080222) Information __________ > > > > > > Diese E-Mail wurde vom NOD32 antivirus system geprüft > > > http://www.nod32.com <http://www.nod32.com> > > > > > > [Non-text portions of this message have been removed] > > > > > > > > __________ NOD32 2897 (20080222) Information __________ > > Diese E-Mail wurde vom NOD32 antivirus system geprüft > http://www.nod32.com [Non-text portions of this message have been removed]
