Re: [Doepfer_a100] A-125 phaser (noise issue)
2008-02-24 by Ross Goniakowski
thanks for all your help...
----- Original Message ---- From: Bakis Sirros <synth_freak_2000@yahoo.com> To: Doepfer_a100@yahoogroups.com Sent: Saturday, February 23, 2008 5:12:53 PM Subject: Re: [Doepfer_a100] A-125 phaser (noise issue) don't know about any adjustment. --- Ross Goniakowski <carfull@sbcglobal. net> wrote: > why didn't you just say that to begin with? i'm not > trying to make an issue, but my phaser is also > noisey as the original poster said...if you would > have simply wrote "mine is as well, they all are, > this is how i deal with it" i would have never > responded to your post, i deal with it as well... > > but i still would like to know if there is an > adjustment to be made that will help with the > noise... > > thanks, > rg > > > ----- Original Message ---- > From: Bakis Sirros <synth_freak_ 2000@yahoo. com> > To: Doepfer_a100@ yahoogroups. com > Sent: Saturday, February 23, 2008 4:34:10 PM > Subject: Re: [Doepfer_a100] A-125 phaser (noise > issue) > > yes, but noise is common in phasers... > > --- Ross Goniakowski <carfull@sbcglobal. net> wrote: > > > sorry...i said i believed you said fix, i > accidently > > deleted the post before responding.. . > > > > so now i say it's not a solution, it's a work > > around...it doesn't deal with the noise of the > phase > > shifter, it masks it... > > > > rg > > > > > > ----- Original Message ---- > > From: Bakis Sirros <synth_freak_ 2000@yahoo. com> > > To: Doepfer_a100@ yahoogroups. com > > Sent: Saturday, February 23, 2008 1:20:32 PM > > Subject: Re: [Doepfer_a100] A-125 phaser (noise > > issue) > > > > that's why i said an easy solution, not a fix ;-) > > > > --- Ross Goniakowski <carfull@sbcglobal. net> > wrote: > > > > > i accidently deleted a reply to this post from > > > Bakis, i believe he said an easy fix was to use > a > > > VCA after the phase shifter... > > > > > > i don't consider that a fix, i consider that a > > > work-around. ..to fix the problem would be to > > reduce > > > the noise level, not hide it...depending on the > > > source material, that may or may not be an > > > appropriate solution.... > > > > > > > > > rg > > > > > > > > > ----- Original Message ---- > > > From: astroschnautzer <astroschnautzer@ > yahoo.com> > > > To: Doepfer_a100@ yahoogroups. com > > > Sent: Saturday, February 23, 2008 8:46:52 AM > > > Subject: [Doepfer_a100] A-125 phaser (noise > issue) > > > > > > I just got this module ,seems to work ok besides > > its > > > terribly noisy. My soundcards noisefloor > > > is at about -90db withoout this plugged in whe i > > > plug it in it shows -47db so over 40 db of > > > noise... Is this normal for this module or > should > > I > > > send it back? > > > > > > > > > > > > > > > [Non-text portions of this message have been > > > removed] > > > > > > > > > > Bakis Sirros - Parallel Worlds / Interconnected / > > Memory Geist > > [Doepfer_a100] group owner > > http://www.parallel -worlds-music. com > > http://www.myspace. com/parallelworl dsmusic > > http://www.myspace. com/interconnect edmusic > > http://www.myspace. com/memorygeist > > http://www.DiN. org.uk > > http://www.musicama ximamagnetica. com > > http://www.shimarec ords.co.uk > > http://www.rubber. gr > > Athens-Greece > > > > ____________ _________ _________ _________ > _________ > > _________ _ > > Looking for last minute shopping deals? > > Find them fast with Yahoo! Search. http://tools. > > search.yahoo. com/newsearch/ category. > php?category= > > shopping > > > > > > > > [Non-text portions of this message have been > > removed] > > > > > > Bakis Sirros - Parallel Worlds / Interconnected / > Memory Geist > [Doepfer_a100] group owner > http://www.parallel -worlds-music. com > http://www.myspace. com/parallelworl dsmusic > http://www.myspace. com/interconnect edmusic > http://www.myspace. com/memorygeist > http://www.DiN. org.uk > http://www.musicama ximamagnetica. com > http://www.shimarec ords.co.uk > http://www.rubber. gr > Athens-Greece > > ____________ _________ _________ _________ _________ > _________ _ > Never miss a thing. Make Yahoo your home page. > http://www.yahoo. com/r/hs > > > > [Non-text portions of this message have been > removed] > > Bakis Sirros - Parallel Worlds / Interconnected / Memory Geist [Doepfer_a100] group owner http://www.parallel -worlds-music. com http://www.myspace. com/parallelworl dsmusic http://www.myspace. com/interconnect edmusic http://www.myspace. com/memorygeist http://www.DiN. org.uk http://www.musicama ximamagnetica. com http://www.shimarec ords.co.uk http://www.rubber. gr Athens-Greece ____________ _________ _________ _________ _________ _________ _ Be a better friend, newshound, and know-it-all with Yahoo! Mobile. Try it now. http://mobile. yahoo.com/ ;_ylt=Ahu06i62sR 8HDtDypao8Wcj9tA cJ [Non-text portions of this message have been removed]
