Doepfer
MAQ 16/3 questions
MAQ 16/3 questions
2002-05-14 by grove@zeta.org.au
I just got an MAQ 16/3 for what I thought was an excellent price.
I can't really afford it, but it was too good to miss!
I'm going to use it to drive some multimbral synths (Kawai K1) & my Mini
system's filter and so on and eventually when I build my bigger system,
that too.
The unit doesn't arrive till next week, but I already have questions.
The manual is pretty thin in some areas for such a complex device so
I was hoping there might be an alternative manual somewhere or a forum
(this one?!) that can help.   I did find an MAQ 16/3 forum elsewhere but it
appears to be dead.
My question is about the presets -  apparently there is 30 of them.
I want to know if the presets can be accessed via MIDI or not.
I was planning on building a few presets and storing them in the MAQ
and then sending commands from Logic to change them at will.   Is this
possible?  I know the MAQ has a lot of MIDI control functions but this
one isn't listed in the manual, or at least I cannot see it.
Also, does someone know if there's a Logic Environment for one of these?
It would be very useful if there were....
BTW, if Roel is reading this, I lost his email address!
rachel
This message was sent using Endymion MailMan.
http://www.endymion.com/products/mailman/
Re: MAQ 16/3 questions
2002-05-15 by ringmod45
hi rachel, it is possible. you can do it through midi program change.
to get single 16th note rests or 16th note values, go to the PA and
PR fields in the event menu while in stop mode, they are all the way
right to end. once you get there you can choose between PA 1 to 5 or
PR 1 to 5. the NA and NR fields are constant 16th notes being output
by each channel. there is no way to tie notes on the MAQ, what a
pity, it's ok none of the other ...werk boxes tie notes either,so
you're not excluded from such a function. in this mode you can turn
each step on or off depending where you turn the step knob to. all
the way to the right turns the step off. anywhere to the left of the
first note on sets the note on and the midi or cv value according to
the octave ratio you have set it to. this is really hard to decipher
from the shitty manual that comes with the unit. most people i have
known that have MAQ's did not know about this feature. hope this
helps.
cheers and good luck,
RM
--- In Doepfer_a100@y..., grove@z... wrote:
> Hi,
Mini
system,
> that too.
questions.
so
forum
elsewhere but it
> appears to be dead.
MAQ
this
this
these?
> rachel
