Doepfer
Trautonium filter on ebay
2008-04-28 by pro2andrius
http://cgi.ebay.es/ws/eBayISAPI.dll?ViewItem&item=180236107714
defective, probably the first stage filter is damaged. otherwise in
good shape , some marks at rack holes!
Re: [Doepfer_a100] Trautonium filter on ebay
2008-04-28 by Bakis Sirros
maybe its just a soldering problem.
in one of my two trautonium filter modules, i also had
one of the three filters defective and i found out
that the long solder 'cord' that was connecting the
three pcb's had lost contact to the defective filter
pcb in question.
i just put a little solder and everything was fine!
best regards,
Bakis.
[Doepfer_a100] group owner
www. parallel - worlds - music. com
www. myspace. com/ parallelworldsmusic
www. myspace. com/ interconnectedmusic
www. myspace. com/ memorygeist
www. DiN. org. uk
www. musicamaximamagnetica. com
www. shimarecords. co. uk
www. rubberrecords. gr
Athens - Greece
Be a better friend, newshound, and
know-it-all with Yahoo! Mobile.  Try it now.  http://mobile.yahoo.com/;_ylt=Ahu06i62sR8HDtDypao8Wcj9tAcJ
Re: Trautonium filter on ebay
2008-04-29 by pro2andrius
many thanks bakis
do you mean the red and grey long wire?
--- In Doepfer_a100@yahoogroups.com, Bakis Sirros
> pcb in question.
> best regards,
> Bakis.
> www. DiN. org. uk
> Athens - Greece
yes, i guess, i soldered a bit on the links to the PCB s but no
success, i measured them with a voltmeter, all is alright, so i don t
know where is the failure...
anyway many thanks for your help!!
Miguel
> no, it's a silver solder 'cord' connecting the various
> filter pcb's.
> check to see if one of these two silver solder 'cords'
> (there are two in the module) is not making good
> contact with one of the 4 pcb's.
> > many thanks bakis
> > had
> > the
> > filter
> > > pcb in question.
> > fine!
> > > best regards,
> > > Bakis.
> > Memory Geist
> > > www. DiN. org. uk
> > > Athens - Greece
> www. DiN. org. uk
> Athens - Greece
Re: [Doepfer_a100] Re: Trautonium filter on ebay
2008-04-29 by Bakis Sirros
filter pcb's.
> many thanks bakis
> had
> the
> filter
> > pcb in question.
> fine!
> > best regards,
> > Bakis.
> Memory Geist
> > www. DiN. org. uk
> > Athens - Greece
www. DiN. org. uk
Athens - Greece
