Doepfer
Dieter Doepfer speaking with Don' Buchla !
2008-05-20 by Eric Normand
Hi ,
 is the first time I post a matter on the forum , my English is to bad
For translate my wish and my ideas :)
I would like to know if it was possible Dieter making a module who
accept the exchange ( Convert  1V/Oct in 1.2, Gate/Pulse,
Minijack/Banane ... ) with Buchla B200e ?
It was nice for persons who have some A100 Modular system , connect
with Complex waveform generator model 261e or 259e  and other ...
Cheers
Eric/belempa
Re: Dieter Doepfer speaking with Don' Buchla !
> Harvestman has a module like this in the planing stage:
> http://www.theharvestman.org/1963.htm
> -C
> Chris Muir
> cbm@...
> http://www.xfade.com
Thank's Chris , but is not in production ( manufacture ) is it ?
Eric
Re: [Doepfer_a100] Dieter Doepfer speaking with Don' Buchla !
2008-05-20 by Chris Muir
-C
Chris Muir
cbm@well.com
2008-05-21 by Eric Normand
--- In Doepfer_a100@yahoogroups.com, <hardware@...> wrote:
> > Hi ,
bad
connect
> > Cheers
> > Eric/belempa
> The 1 -> 1.2 V/octave conversion can be realized with a modified A-
185-2. We
> could manufacture a special version of the A-185-2 with an
amplification of
> 1.2 instead of 1.0. The additional charges will be not too much as
only a
> couple of resistors have to be replaced (120k instead of 100k). The
mini
> jack -> Banana conversion can be realized DIY (nothing but a blind
panel
> with  a jack socket and a banana socket internally connected).
> Best wishes
> Dieter Doepfer
> P.S. Why are they called Banana ? I can't see any similarity :-)
Hi Dieter ,
Thank's for reply ,
Yes it was nice if you could manufacturate this module .
But it would need also the "A-185-1" Bus-access ?
On the B200e CV/Gate is : Pitch and Note on .
I don't know too Why Bananas live in B200e ! :D
Eric/belempa
AW: [Doepfer_a100] Dieter Doepfer speaking with Don' Buchla !
2008-05-21 by hardware@doepfer.de
> Hi ,
> Cheers
> Eric/belempa
The 1 -> 1.2 V/octave conversion can be realized with a modified A-185-2. We
could manufacture a special version of the A-185-2 with an amplification of
1.2 instead of 1.0. The additional charges will be not too much as only a
couple of resistors have to be replaced (120k instead of 100k). The mini
jack -> Banana conversion can be realized DIY (nothing but a blind panel
Best wishes
Dieter Doepfer
Re: AW: [Doepfer_a100] Dieter Doepfer speaking with Don' Buchla !
2008-05-21 by James Husted
The "banana" similarity is in the banana plug, not the banana jack.
Think of a straight banana and the ridges of the banana peel look
similar to the metal-spring-like sides of the connector on the banana
plug.
I don't think I have ever types banana this many times in a message
before...
-James
I made a photo to the files section to show this a little better I
hope (love that PhotoShop):
http://launch.ph.groups.yahoo.com/group/Doepfer_a100/photos/browse/
f53b?c=
-James
2008-05-22 by Eric Normand
--- In Doepfer_a100@yahoogroups.com, James Husted
> f53b?c=
> -James
Hi James,
Nice Banana Jacks :-)  and good work with Photoshop .
Eric/belempa
2008-05-22 by James Husted
Thanks! - I'm in Photoshop about 80% of my workday - sigh...  It
would have been a lot better work if I had takes the photos myself
(the other 20% of the workday), I just snagged them off the net.
Wait till I get time to mock up a pic of a VC iPod nano module I
would love to have designed for me.
-James
>> f53b?c=
>> -James
> Hi James,
> Eric/belempa
2008-05-22 by Chris Muir
There's also the issue of Gate & Trigger <-> Buchla Pulse
I may be a little off on the specifics here (I don't have a scope) but
the Buchla pulse jacks carry the equivalent of a gate and trigger. The
trigger is imposed on the gate level. Bad ASCII art:
        _
10v   | |
5v    | ----
0v. ---     ------
-C
Chris Muir
cbm@well.com
That is a very neat method (combining a gate and a trig in one signal)
- I didn't know they did that. I imagine that summing both a 5V
trigger and a 5V gate would do that. When both are present you would
get the Buchla Pulse. The summing would not have to be spot-on to
work. I would think a circuit that took a Doepfer gate in, did a
rising edge detection to produce a trig and summed it with the
original gate would work.
-James
>        _
> 10v   | |
> 5v    | ----
> 0v. ---     ------
> -C
> Chris Muir
> cbm@well.com
AW: AW: [Doepfer_a100] Dieter Doepfer speaking with Don' Buchla !
2008-05-23 by hardware@doepfer.de
> > _
> > 10v | |
> > 5v | ----
> > 0v. --- ------
> > -C
> > Chris Muir
To obtain this signal you simply have to add the gate and the trigger (e.g.
with an A-138 though this module is a bit overstated for this function,
probably two resistors can do the same job too).
To obtain gate and trigger from such a signal two comparators are required
(e.g. A-167), one for the "window" between 0 and +5V (gate) and one for
+5...+10V (trigger). It would be very easy to built such a module but I'm
not sure if there are sufficient inquiries. And if Scott Jaeger has such a
module in the planning state we will not compete with him.
Best wishes
Dieter Doepfer
2008-05-26 by Eric Normand
scope) but
trigger. The
> > > _
> > > 10v | |
> > > 5v | ----
> > > 0v. --- ------
> > > -C
> > > Chris Muir
trigger (e.g.
function,
required
for
but I'm
such a
> Best wishes
> Dieter Doepfer
Hi , Dieter, Chris ,
Well ,
 I have to wait for this Scott Jaeger module so if I want one day to
make some topic' between A100 and my small B200e , ;-)
Cheers
Eric/bemlempa
