Hi Pierre,
I got them from Jameco.com - they don't carry my exact part number anymore, but here's
one that may be just like it:
http://www.jameco.com/webapp/wcs/stores/servlet/ProductDisplay?langId=-
1&storeId=10001&catalogId=10001&productId=136241
These set-screw type knobs expect a 1/4" (6.25mm) shaft, so they're slightly too large for
the smaller 6mm Doepfer knob shafts. But I found sliding a cut straw piece over the shaft
can make the knobs fit pretty good. You may have to try various straws to find one that's
the optimal thickness.
Also it's not obvious when you get them, but there's a protective clear plastic covering on
the aluminum top. You can gently peel it off with your finger nail and not damage the top
finish.
--- In Doepfer_a100@yahoogroups.com, "pfichoux" <pfichoux@...> wrote:
> Dear Laryn91,
> Could you let us know were you found those delightful knobs ?
> Best,
> Pierre
