Doepfer
Anybody used these modules?
2002-05-23 by jmaddocks1975
Hi All,
Anyone used the new 18db Filter yet?
Does it sound like a TB303?
What about the frequencer Shifter, it sounds so interesting but I
would like to hear peoples opinion before buying, it is one of the
most expensive module.
Is it any good?
Also the Subharmonic Osc. sounds very interesting, anyone used one?
I'm about to purchaes a few new modules but not made my mind up which
to buy yet so a few opinions are VERY appriciated.
Thanks a lot!
John
Re: Anybody used these modules?
2002-05-23 by code_pig
John,
I recently purchased an A126 (Frequency Shifter), and like it quite a
bit.  My only complaint is that the shift frequency only goes down to
50Hz (unlike the EMS Frequency Shifter which, if I remember
correctly, goes down to either 10Hz or 25Hz... but it's been a long
time since I owned one).
Anyway, I tend to process percussion through the A125 with very
positive results.
If you don't mind the price, the A126 will give you countless hours
of weirdness.  That said, be prepared to spend a little time working
with the module, as it certainly isn't an "instant gratification"
device.
Kevin Lamb
Re: Anybody used these modules? / (a113)
2002-05-24 by duffnuff
used one?
i'll take a minute to comment on the a113..
it's an interesting module in that it allows you to play 'chords' of
just about any musical or dissonant context, all from a single
square wave Osc signal, and allows you to store 'mixturs' in
banks which can be recalled on the fly using footswitches or
other gate signals for changing 'chords' as you play.  this is
described in detail on the doepfer site and it works as expected
in this capacity, many rich tones are to be had.  if you're looking
for subharmonics in a 'dope bass' sorta way, this won't do it, (the
a113 only processes square waves and in turn outputs sawtooth
waves) so for the super deep 'subharmonic' bass you're better
off w a self oscillating LP filter or sine wave Osc.
and for those of you who remember my moaning about the lack
of an odd-factor clock divider a while back...
i have to say the most note-worthy dicovery i've made recently is
using the a113 as a clock divider.  this is very cool for dividing a
clock pulse by odd factors of 3, 5, 6, 7, etc...even better when
different divisions are mixed via 138.  try this w dynamic mixing
within the 138 for bringing polyrhythmic elements in and out.
as you may know,  most conventional clock dividers only divide
by factors of 2, 4, 8, 16, etc., so what makes the a113 extra
special in this regard is not only the odd division capability but
the fact that there are 4 of them available simultaneously w an
indiv output per divider.  as you can imagine, this can pull some
downright naughty rhythms out of the a155. (and we all know
what sawtooths do to the a155)  but if you prefer less
randomness step-wise, run the a113's sawtooth output through
a signal modifier such as a160 seq or a162 trig delay (both
settings at zero) and it straightens it back into a 1-2-3-4-5-6-7-8
trig signal, giving you an honest, odd but ordered division rather
than having the a155 jump steps all over the place ( but in time)
from the sawtooth.  try it both ways!
so overall i'd say the a113 a very unique module w many
interesting applications that would require very complicated
patching otherwise..conventional? no.  fun?  yes.  i think it's
great.
-duff
Re: [Doepfer_a100] Re: Anybody used these modules? / (a113)
2002-05-24 by bakis Sirros
hi list,
thanks duff, very interesting use of the a113!!!i have
one but i have never tried something like it...
bakis.
> anyone
> used one?
> play 'chords' of
> from a single
> 'mixturs' in
> footswitches or
> play.  this is
> as expected
> you're looking
> won't do it, (the
> sawtooth
> you're better
> the lack
> made recently is
> cool for dividing a
> better when
> dynamic mixing
> and out.
> only divide
> a113 extra
> capability but
> simultaneously w an
> can pull some
> all know
> less
> through
> delay (both
> 1-2-3-4-5-6-7-8
> division rather
> but in time)
> many
> complicated
> think it's
> great.
> -duff
synthfreak(parallel worlds)
athens-greece
[Doepfer_a100] group owner-moderator
Do You Yahoo!?
Yahoo! Tax Center - online filing with TurboTax
http://taxes.yahoo.com/
2002-05-24 by buechlerjoe
Good stuff, duff :-)
Makes me want to get one!
Joe
> used one?
> great.
> -duff
