On Jul 19, 2008, at 4:32 PM, williambbaggett wrote:
> Hi Group, and thanks for your many suggestions about how I might
> use banana cords to
> interface with a Serge system.
> Well, I've ordered but not yet received a pretty larger Doepfer
> system, and based on the
> advice received here, am prepared to drill out the plastic in the
> middle of the 3.5mm
> mini-plugs just a bit so as to to allow them to receive 4 mm banana
> plugs. (instead of
> patch bays or adapter cables, etc.)
> I understand now that I have to disconnect ground from ever "banana
> adapted" socket or
> else I would ground out the signal coming in on the banana.
> However, I can't understand why trying to use banana jacks in
> normaled sockets would
> not create a similar problem. I dunno, but need to know soon -
> since I don't intend to
> touch a normaled socket until I do.
> THE ONE THING I CAN'T FIGURE OUT IS:
> James (or was it Korhan?) wrote:
>>> if carefully done the tip part of the jack could still be used and
>>> make
>>> contact with the banana and EVEN THE NORMALIZING PRESERVED.
> I admit to being no expert and certainly capable of asking questions
> without being able to
> understand the (correct) answer, but I don't really get it and I
> certainly want to make sure
> before I stick a a banana pug in a drilled out/enalarged NORMALED
> socket.
> Do I need to:
> (1) just leave the normaled mini-phone sockets ALONE and only drill
> out the sockets that
> aren't?
> (2) somehow disable the normaling and waste a patch cord or 4 now
> and then? (& If so,
> how?)
> (3) treat normaled sockets just like the rest
> It's this 3rd option I don't understand, and is why I write.
> I looked at a schematic of a switched jack and it looked like
> "normally" the normaled
> connection between 2 contacts is broken by the insertion of a mini-
> plug (The insertion
> separates 2 contacts that would "normally" be connected)
> Here's the part that worries me – while the normalled connection is
> broken, one contact is
> touching the tip of the mini-phone jack and the other contact is
> isolated and touching the
> sleeve (or whatever you call it) of the mini-plug.
> So. since the banana plug has no sleeve, the two contacts would NOT
> be isolated and the
> connection between the 2 contacts would NOT be broken when a banana
> plug is inserted.
> Also, seems like the same banana plug would be connected to both
> contacts and – So,
> what would happen to the signal carried by the banana cable? It
> seems like this might
> result in stacking inputs (1. the normalled input that wasn't
> disconnected with the plug
> was inserted and 2. the signal coming from the plug itself.)
> Well, the "question" turned out longer than I expected. Sorry, but
> I'd appreciate any
> advice. I hope I'm wrong and can somehow use normalled inputs with
> banana plugs, but I
> dunno... Whattaya think ?
> Thank
> Billy
> P.S. Please let me know if any of you have any ideas or can foresee
> any potential
> problems, etc. Thanks again!
