Doepfer
a doubt
a doubt
2008-08-07 by pro2andrius
i have now two doepfer systems, one has the old a100 PSU and the other
has the newer PSU2, with the ring core trafo. i noticed a difference
in the output levels, the PSU2 deliver higher output, easy to distort
at maximum, it s this normal or perhaps i did something wrong?
thanks for your help
Miguel
AW: [Doepfer_a100] a doubt
2008-08-07 by hardware@doepfer.de
> Miguel
The old PSU cannot be the reason for a smaller output - provided that the
old PSU is not defective or mis-adjusted. Both supplies deliver +12V
and -12V. The only difference is the max. output power (650mA vs. 1200 mA)
and the type of transformer. The transformer of the old PSU is not the ring
core type and may cause additonal hum noise in sensitive audio processing
modules (mainly in the spring reverb A-199).
Try the samle module in both frames (e.g. an A-110). If there are indeed
different output levels the old PSU is probably defective or mis-adjusted or
overloaded (i.e. more tha 650 mA total current).
Best wishes
Dieter Doepfer
Re: a doubt
2008-08-14 by floris vanhoof
sometimes when an lfo and bbd are in the same psu i can hear very silent lfo pulses in the
output. i'm using the low cost psu.
is the bbd also a sensitive audio processing module? (should i use a ring core psu for less
noise?)
+ also, is it possible to build in a filter in the bbd module to suppress the clock? (like  in
the serge wilson delay) anyone done this? or got an idea when the filter for this module
will be ready?
best, floris
> > Miguel
> Best wishes
> Dieter Doepfer
