Doepfer
basic circuit question
2008-08-10 by Monroe Eskew
Can someone answer the question of how to make a pot scale more
finely?  If you insert a resistor in the output path, does this divide
the voltage and weaken the effect of the pot?  I don't know much about
circuits.
Re: basic circuit question
2008-08-10 by Stu Grimshaw
--- In Doepfer_a100@yahoogroups.com, Monroe Eskew <monroe.eskew@...>
> circuits.
if you have a resistor of, say 100 ohms, you can connect another 100
ohm fixed resistance across its outside terminals (legs) and you will
now have a combined resistance of 50 ohms (they are said to be
connected "in parallel"). the pot will now sweep between zero and
fifty ohms, giving you only half the range but double the sensitivity.
using a smaller resistance will give you even more sensitivity.
if you're interested in the maths: combine two resistances a and b in
parallel to give resistance c
1/c = 1/a + 1/b
hope this helps,
stu
2008-08-10 by Tim Stinchcombe
divide
about
> circuits.
The answer is not very straightforward, as it depends on how the pot is
being used. Generally to have more control with a pot, i.e. so that
larger movements have less effect, so you can finely position it to
*just* where you want it to be, you have to reduce its value. But then
depending on how the pot is being used, you will need to add one or
more resistors to compensate for this lowering of value: if the pot is
actually being used as a potential divider (that is how the
name 'potentiometer' is derived), you will need to add resistors either
side to bring the total back up to the original value, but how much
each side will depend on where out of the total range, the now reduced
pot is to have its effect; if it is being used as a variable resistor
(the wiper connected to either end or one end left open), again another
resistor will probably be needed, but you will only need one, and which
side of the pot it goes will not matter.
If you have a particular pot in mind on a particular module, I might be
able to make suggestions on exactly *what* values to use and *where* to
add the resistors (depending on whether I have the circuit for that
module of course!), but if it was a general question, then I'd suggest
your best course of action would be to either look around on the web
for some basics electronics sites (there will be tons out there!), or
buy a beginners book (your local Maplins/Radio Shack/whatever will
undoubtedly have something suitable), and then get studying! I'm afraid
there is not substitute for you putting in some work in order to gain
some understanding of how all this stuff works!
Tim
Hi Monroe,
> It is for a Plan B envelope generator (elf).  The time range of the
> A,D,R events is much too wide, making it so that only a small angle
of
> turn contains useful settings.  So what would you recommend?
On the face of it it looks like decresing the pot values is what you
need to do, *BUT*, because of the 'add on' module to give voltage-
control of everything, the circuitry in the main module will
necessarily be more complicated, and so this might not be an obvious
mod to do. My recommendation would be to ask Peter Granader directly,
over on the Plan B group.
> I'm confused about what Stu said.  Increasing resistance increases
> voltage throughput?
No it won't, but he didn't actually say that.
>  If you go to infinite resistance by breaking the
> path then no signal goes through.  If you add a resistor in a series
> circuit, the voltage across each other resistor drops.  Intuitively,
> resistors slow down current, so adding resistance in the current
path
> should decrease the energy of the signal.  So shouldn't the effect
be
> the opposite?
Most of what you say here is more or less right. Stu was talking
about adding another resistor *in parallel* (so they are joined
together at both ends), what you are talking about above is adding
them *in series*, and there is a big difference. When added in
parallel, a second resistor of the same size as the existing one will
pass the same current as the first, so you now have twice the current
flowing, which effectively looks like you have halved the resistance.
(And for what it is worth, I think what Stu said will only work for
the 'variable resistance' way of using pots, and not for
the 'potential divider' way!)
Tim
Re: [Doepfer_a100] Re: basic circuit question
A,D,R events is much too wide, making it so that only a small angle of
I'm confused about what Stu said.  Increasing resistance increases the
voltage throughput?  If you go to infinite resistance by breaking the
resistors slow down current, so adding resistance in the current path
should decrease the energy of the signal.  So shouldn't the effect be
the opposite?
Monroe
>  divide
>  about
>  > circuits.
>  Tim
