Loose joystick?
2008-10-15 by elminkopeligroso
Hi (sorry for the spam-like subject line) I just received a Dopefer joystick from Thomann. It's installed fine and does what it's supposed to do, but I've noticed that the shaft is very loose at its base. So much so in fact that it when I let it rest it seems to be at a slightly different offset position each time - I can see because the LEDs light up and I have to keep tweaking the offset dial to return it to zero. Can anyone else with a joystick tell me if this is normal, or should I be returning mine for a replacement. Thanks in advance Mark
