Doepfer
Re: [Doepfer_a100] Re: Loose joystick?
2008-10-16 by york luethje
Hi Mark,
well, I have two joysticks, one sprung and one unsprung. The one with the springs in it is not totally snug in the center position but there are definitely no variations in the CV coming out. It appears to be more of a mechanical problem with the mounting that doesn't affect performance. I've been using the unsprung joystick much more and have never had an issue with it, quite to the contrary.
Anyway, hope you still have fun with yours,
York
----- Original Message ----
Sent: Wednesday, October 15, 2008 8:04:57 PM
Subject: [Doepfer_a100] Re: Loose joystick?
Hi York
Thanks for this - I actually want to remove the springs anyway - it's not the springs I don't
think, more sliding slot at the centre of the joystick that the stick itself is attached to. I
spoke to a friend who has a Doepfer joystick and he said that his was the same, so
perhaps this looseness is inherent in the design.
Thanks
Mark
--- In Doepfer_a100@ yahoogroups. com, york luethje <ybl@...> wrote:
> Hi Mark,
> the joystick should return to its default position every time (unless you have removed
the springs within it). You can try to screw the shaft tighter to its base, but from what you
describe it appears that the springs inside have either come lose or are faulty.
> Have you taken a look at the springs?
> Best
> York
> From: elminkopeligroso <mark.pilkington@ ...>
> To: Doepfer_a100@ yahoogroups. com
> Sent: Wednesday, October 15, 2008 9:52:08 AM
> Subject: [Doepfer_a100] Loose joystick?
> Hi
> (sorry for the spam-like subject line)
> I just received a Dopefer joystick from Thomann.
> It's installed fine and does what it's supposed to do, but I've noticed that the shaft is
very
> loose at its base. So much so in fact that it when I let it rest it seems to be at a slightly
> different offset position each time - I can see because the LEDs light up and I have to
keep
> tweaking the offset dial to return it to zero.
> Can anyone else with a joystick tell me if this is normal, or should I be returning mine
for a
> replacement.
> Thanks in advance
> Mark
2008-10-16 by Sean Williams
Hi York
when you remove the springs on these units does the joystick stay
where you leave it or does it flop down to the bottom, i.e. is there
any mechanical resistance once the springs have gone?
thanks
sean
>Hi Mark,
>York
><<mailto:mark.pilkington%40gmail.com>mark.pilkington@gmail.com>
>To: <mailto:Doepfer_a100%40yahoogroups.com>Doepfer_a100@yahoogroups.com
>Hi York
>was the same, so
>Thanks
>Mark
>>  Hi Mark,
>are faulty.
>>  Best
>>  York
>>  Hi
>very
>keep
>for a
>>  replacement.
>>  Thanks in advance
>>  Mark
