Doepfer
Re: [Doepfer_a100] Re: Loose joystick?
2008-10-16 by york luethje
Hi Sean,
the joystick stays in the same position you leave it in, no movement.
Hope this helps,
York
----- Original Message ----
Sent: Thursday, October 16, 2008 4:07:36 AM
Subject: Re: [Doepfer_a100] Re: Loose joystick?
Hi York
when you remove the springs on these units does the joystick stay
where you leave it or does it flop down to the bottom, i.e. is there
any mechanical resistance once the springs have gone?
thanks
sean
>Hi Mark,
>well, I have two joysticks, one sprung and one unsprung. The one
>with the springs in it is not totally snug in the center position
>but there are definitely no variations in the CV coming out. It
>appears to be more of a mechanical problem with the mounting that
>doesn't affect performance. I've been using the unsprung joystick
>much more and have never had an issue with it, quite to the contrary.
>Anyway, hope you still have fun with yours,
>York
>From: elminkopeligroso
><<mailto:mark. pilkington% 40gmail.com>mark.pilkington@ gmail.com>
>To: <mailto:Doepfer_ a100%40yahoogrou ps.com>Doepfer_a100@ yahoogroups. com
>Sent: Wednesday, October 15, 2008 8:04:57 PM
>Subject: [Doepfer_a100] Re: Loose joystick?
>Hi York
>Thanks for this - I actually want to remove the springs anyway -
>it's not the springs I don't
>think, more sliding slot at the centre of the joystick that the
>stick itself is attached to. I
>spoke to a friend who has a Doepfer joystick and he said that his
>was the same, so
>perhaps this looseness is inherent in the design.
>Thanks
>Mark
>--- In Doepfer_a100@ yahoogroups. com, york luethje <ybl@...> wrote:
>>  Hi Mark,
>>  the joystick should return to its default position every time
>>(unless you have removed
>the springs within it). You can try to screw the shaft tighter to
>its base, but from what you
>describe it appears that the springs inside have either come lose or
>are faulty.
>>  Have you taken a look at the springs?
>>  Best
>>  York
>>  From: elminkopeligroso <mark.pilkington@ ...>
>>  To: Doepfer_a100@ yahoogroups. com
>>  Sent: Wednesday, October 15, 2008 9:52:08 AM
>>  Subject: [Doepfer_a100] Loose joystick?
>>  Hi
>>  (sorry for the spam-like subject line)
>>  I just received a Dopefer joystick from Thomann.
>>  It's installed fine and does what it's supposed to do, but I've
>>noticed that the shaft is
>very
>>  loose at its base. So much so in fact that it when I let it rest
>>it seems to be at a slightly
>>  different offset position each time - I can see because the LEDs
>>light up and I have to
>keep
>>  tweaking the offset dial to return it to zero.
>>  Can anyone else with a joystick tell me if this is normal, or
>>should I be returning mine
>for a
>>  replacement.
>>  Thanks in advance
>>  Mark
>>  [Non-text portions of this message have been removed]
