Doepfer
Analogue Systems in Doepfer case
2008-10-22 by achtung_999
Hello list,
There should be a Analogue Systems module coming my way soon.
For me this is a first of having an other manufacturers module in my A100 system.
I have read about the different power standard that AS uses. Most people tell me to not
produce the ribbon cable convertor myself..
Can anyone recommend a dealer selling these cables/boards. The ones at Analog Haven with
the board look very good. At Schneiders Büro I could not find them in the database
anymore.. Were they selling the same ones?
anyone?
Greetings,
Ernst
Re: [Doepfer_a100] Analogue Systems in Doepfer case
2008-10-22 by James Husted
I have bought and used the ones from Analog Haven and they work very
well. You have to make sure it is plugged together correctly - trace
the lines yourself, don't follow the pictures on the site (which used
to show wired in both ways). Connect it like the 3rd picture down on
the page ( http://www.analoguehaven.com/doepfer/asysadaptor/ ). As
you can see the red stripes DON'T line up on the cables. I also added
some electrical tape covering the exposed leads on the PCB in case it
flopped around and touched anything in the case.
The only other concern is the 1/2 a hp hole spacing difference from
Doepfer and AS modules. Expect a gap or break out the drill press!
-James
On Oct 22, 2008, at 9:05 AM, achtung_999 wrote:
> Hello list,
> my A100 system.
> in the database
> anyone?
> Greetings,
> Ernst
AW: [Doepfer_a100] Analogue Systems in Doepfer case
2008-10-22 by yahoo@doepfer.de
> -James
As mentioned several times we have 1.5 HP blind panels available to avoid
these gaps !
Best wishes
Dieter Doepfer
Re: AW: [Doepfer_a100] Analogue Systems in Doepfer case
Dieter-
  And thanks for making them! I know they are probably not a hugely
selling product either. I have already hacked my AS stuff (and
reducing it's resale prices accordingly). Unfortunately for me at the
time I would not be willing to let go of 3-hp of panel space (one in
each side of a bank of AS). Things are different now. As a old metal
work guy I really see changing the hole punch currently used by
everyone to a slot punch instead as a much better solution (Cwejman
seems to be the only one doing this). That way any module can be used
in any system. Changing punches should cost nothing more than a
programming fee for older modules already in production and nothing
for newer modules.
-James
>> -James
> avoid
> these gaps !
> Best wishes
> Dieter Doepfer
2008-10-22 by Guy Drieghe D.
James,
Can you please enlighten the non-metal workers (and non-native English
speaking) amongst us as to what exactly "hole punch" and "slot punch"
thingies are ?
tia !
- Guy
On 22 Oct 2008, at 20:41, James Husted wrote:
> Dieter-
> for newer modules.
> -James
> >> -James
> > avoid
> > these gaps !
> > Best wishes
> > Dieter Doepfer
2008-10-22 by neil jendon
If you look at the faceplates of Cwejman modules, the mounting holes are racetrack-shaped rather than just round holes. It gives a little bit of wiggle room.
--- On Wed, 10/22/08, Guy Drieghe D. <guy@guyd2.com> wrote:
Subject: Re: AW: [Doepfer_a100] Analogue Systems in Doepfer case
Date: Wednesday, October 22, 2008, 2:04 PM
James,
thingies are ?
tia !
- Guy
> Dieter-
> reducing it's resale prices accordingly) . Unfortunately for me at the
> for newer modules.
> -James
> >> -James
> > avoid
> > these gaps !
> > Best wishes
> > Dieter Doepfer
Oh yes, I see. Makes a lot of sense indeed.
Thanks !
-g
> bit of wiggle room.
> From: Guy Drieghe D. <guy@guyd2.com>
> James,
> thingies are ?
> tia !
> - Guy
> > Dieter-
> the
> used
> > for newer modules.
> > -James
> from
> press!
> > >> -James
> to
> > > avoid
> > > these gaps !
> > > Best wishes
> > > Dieter Doepfer
In most sheet metal work, the holes are not drilled and the metal is
not sawed. The holes are typically punched out of the sheet metal
(usually a 4 foot x 8 foot sheet) by a large multi-headed numerically
controlled punching machine. The operator programs in all the hole
locations and the type of tool used (round, square, oblong, hex, or
special like a RS-232 connector) and its orientation if needed. The
sheets are programmed to be punched with the highest yield of parts
possible. That is why custom parts are expensive. You have to have a
large part count to make it worth punching. Typically the metal shop
will try to mix jobs from different clients using the same gauge
metal to lower cost otherwise extra metal left over is recycled at a
loss. The edges are punched with a series of long slot punches. You
can see marks along the edge of a panel where the punches overlap
unless a post-process sanding cleanup is done. Also typically the
front face is called out and the job is specified weather the holes
are to be punched from the front or rear surface. If you look closely
at the edges of the holes you can see this as a very sharp edge on
the exiting side and a small rounded edge on the side where the punch
hits the metal. This get more obvious as the punch wears out and
doesn't punch as cleanly.
The type of holes that one can have punched are totally limited by
the sheet metal house. It is limited by what punches they have in
stock. Most houses will have a huge variety of round and square hole
sizes and allot of the common slot sizes (used by rack ear holes for
instance) along with commonly used custom holes like for IEC power
connectors and computer serial connectors. Most odd shapes can be
made by punching combinations of smaller holes too. If a client needs
an odd shape hole that will be used a lot in a job, a custom punch
will often be made to add to the sheet metal house's library.
Doepfer's metal shop may not have the small slot punches mentioned
and they may want way too much to make a custom punch.
I hope that helps. I can tell you from experience that seeing a large
sheet metal machine pound out a piece is very impressive. Here is a
link to a site that shows the whole process: <http://www.industrial-
computer-source.com/white_paper_sheet_metal.html>
James
On Oct 22, 2008, at 12:04 PM, Guy Drieghe D. wrote:
> James,
> thingies are ?
> tia !
> - Guy
>> Dieter-
>> for newer modules.
>> -James
>>>> -James
>>> avoid
>>> these gaps !
>>> Best wishes
>>> Dieter Doepfer
Thanks for the extensive explanation, James.
Always nice to learn something, especially when it's fringe-related to
one's interests.
I saw a couple of NG series on telly about "how things are made", and
I was mighty impressed with all these heavy machinery punchers and
presses and plasma cutters... quite fascinating. Sometimes scary too,
a bit.
Also a stunner to watch (on Apple's website): how a solid block of
aluminum is machined into something as refined as the latest MacBooks.
-g
> James
> > James,
> English
> punch"
> > thingies are ?
> > tia !
> > - Guy
> >> Dieter-
> the
> in
> metal
> used
> >> for newer modules.
> >> -James
> from
> press!
> >>>> -James
> to
> >>> avoid
> >>> these gaps !
> >>> Best wishes
> >>> Dieter Doepfer
> > Yahoo! Groups Links
2008-10-23 by achtung_999
Thanks for the tips. I went for the analog haven cable to be sure..
> one's interests.
> a bit.
> -g
> > James
> > > James,
> > English
> > punch"
> > > thingies are ?
> > > tia !
> > > - Guy
> > >> Dieter-
> > the
> > in
> > metal
> > used
> > >> for newer modules.
> > >> -James
> > >> On Oct 22, 2008, at 11:06 AM, yahoo@doepfer.de <yahoo%40doepfer.de>wrote:
> > from
> > press!
> > >>>> -James
> > to
> > >>> avoid
> > >>> these gaps !
> > >>> Best wishes
> > >>> Dieter Doepfer
> > > Yahoo! Groups Links
