Doepfer
Re: AW: [Doepfer_a100] Let me hear your bright new ideas for future
2008-10-29 by mark francombe
1)
As someone who likes to run external audio signals thru my modular (guitar
mostly) I would like a pitch SHIFTER... But with all the tweakage one would
expect on a modular, and a quantiser built in. The ability to have a
sequencer (155) play a tune on an oscillator AND change the pitch shifting
on a pitch shifter would be great... I curently do this by routing CVs out
to the pedal input of a stomp box pitch shifter, but its not giving known
pitches that are musically the same as 1 octave per volt. So this would be
lovely!!
2)
A new sampler module, the curent one is great, but I want/need something
that can be set to record via a gate signal, and has variable in and out
(sample trim) points (this might be simerlar, the same as the Harvestman
module, n´dont know, havent got one... yet)
3a)
This ones more fuzzy... I imagine a filter, that is at one end of its range
a regular filter, which REMOVES frequencys from an input, but at the other
end ADDs frequencies. Soft to harsh in one box. variable (CV-able) Freqency
cutoff/add, Q control, and someway to vary continously the frequencys you
are cutting and adding...
3b)
Also filters always have a switch to choose whether its a Low pass, Band
pass or high pass... why not 2 variable controls one for the bottom limits
of the filter one for the top limits. So if the Bottom control was at 0 and
the Top at 3 you get a Low pass, Bottom is at 6 top is at 10, you get a High
pass, Bottom is at 3, top is at 6, you get a band pass?
4)
Oh and I want a simple combination VCA and AR module, 2 at least in one
panel...(just an audio in out and a gate input for each) I REALLY REALLY
HATE having to patch a ADSR to a VCA everytime... and I NEVER use D or S...
cos Im always sequencing/triggering, not playing a keyboard.
Mark
www.markfrancombe.com
http://vimeo.com/user825094
http://uk.youtube.com/user/markfrancombe
http://www.myspace.com/markfrancombe
www.looop.no
AW: AW: [Doepfer_a100] Let me hear your bright new ideas for future
2008-10-30 by yahoo@doepfer.de
You find some comments inline
Dieter Doepfer
> 1)
would
> lovely!!
Currently I see no way to built an analog pitch shifter with acceptable
efforts/costs.
But the VC DSP module will include a pitch shifter. Let's see how it
works/sounds and if 1V/Oct control is possible. We are still working on this
module and will have to find out if it can be made.
> 2)
Probably the planned digital delay module will be able to do this job (but I
cannot promise it at this state of the design, we will have to find out if
the calculation power of the microcontroller is sufficient for these
additional features)
3a)
range
Freqency
A combination of the wave multiplier A-137-1 (adds frequencies/harmonics)
and a low pass filter ?
> 3b)
and
High
Technically no problem but would increase the price of a filter clearly (for
some filters it would double the price or even more) as one needs a three
way VC mixer (i.e. 3 VCAs with a common output) and a small morphing
controller like the A-144 but with 3 outputs only. You can realize this with
existing modules: A-135 and A-144.
> 4)
> D or S... cos Im always sequencing/triggering, not playing a keyboard.
That's already on our to-do-list (another A-143-x module): a quad VCA with
separate A/R generator for each VCA
b.t.w. some more economically priced quad modules are in the holding
pattern: a quad VCLFO/VCO, a quad VCA with common/separate CV controls and
common/separate outputs, and the mentioned quad VCA/AR.
> Mark
> www.looop.no
Re: AW: AW: [Doepfer_a100] Let me hear your bright new ideas for future
2008-10-30 by Bakis Sirros
ok, so'll keep in mind idea #3b for a poll. the others are probably covered...
[Doepfer_a100] group owner
www. parallel - worlds - music. com
www. myspace. com/ parallelworldsmusic
www. myspace. com/ interconnectedmusic
www. myspace. com/ memorygeist
www. DiN. org. uk
www. musicamaximamagnetica. com
www. shimarecords. co. uk
www. rubberrecords. gr
Athens - Greece
--- On Thu, 10/30/08, yahoo@doepfer.de <yahoo@doepfer.de> wrote:
Subject: AW: AW: [Doepfer_a100] Let me hear your bright new ideas for future
Date: Thursday, October 30, 2008, 10:41 AM
Dieter Doepfer
> 1)
would
> lovely!!
efforts/costs.
> 2)
3a)
range
Freqency
A combination of the wave multiplier A-137-1 (adds frequencies/ harmonics)
> 3b)
and
High
> 4)
> D or S... cos Im always sequencing/triggeri ng, not playing a keyboard.
> Mark
> www.markfrancombe. com
> http://vimeo. com/user825094
> http://uk.youtube. com/user/ markfrancombe
> http://www.myspace. com/markfrancomb e
> www.looop.no
2008-10-31 by achtung_999
I like the idea of that Quad VC-LFO Dieter!!!Any idea when this will be
available?
* holds back buying  the MFB dual vc-lfo *
On Thu, Oct 30, 2008 at 10:09 AM, Bakis Sirros
> covered...
> www. DiN. org. uk
> Athens - Greece
> --- On Thu, 10/30/08, yahoo@doepfer.de <yahoo%40doepfer.de> <
> yahoo@doepfer.de <yahoo%40doepfer.de>> wrote:
> From: yahoo@doepfer.de <yahoo%40doepfer.de> <yahoo@doepfer.de<yahoo%40doepfer.de>
> future
> To: Doepfer_a100@yahoogroups.com <Doepfer_a100%40yahoogroups.com>
> Dieter Doepfer
> > 1)
> (guitar
> would
> shifting
> out
> be
> > lovely!!
> efforts/costs.
> this
> > 2)
> I
> 3a)
> range
> other
> Freqency
> > 3b)
> limits
> and
> High
> (for
> with
> > 4)
> > Mark
> > www.looop.no
> > Yahoo! Groups Links
2008-11-01 by Korhan Erel
Hi there!
While I was reading all these messages on future modules and
interaction with computers, an idea sprung up in my mind: a hardware
box of, let's say 16 CV generators, that connects to a computer thru
USB, that runs a software for sequencing those CV outputs. The
sequences are ideally not MIDI based, but use a exclusive hi-res
format (the idea of breaking a normally continuous CV signal into 127
steps is not a good idea). Sequences can be created either with a
graphic editor that uses curves (including bezier curves) or with some
sort of a step editor. The user can dedicate some of the CV outs as
LFOs that they can draw on the screen. This software should be able to
sync with other MIDI/Audio sequencers so that the user can combine
computer sounds, etc with their modular.
Would this be insanely expensive? Or is there already a box like this
(leaving the MIDI-2-CV converters out)
Korhan
2008-11-01 by Bakis Sirros
isn't that the same with the proposed (USB) OSC to cv/gate module?
www. DiN. org. uk
Athens - Greece
--- On Sat, 11/1/08, Korhan Erel <listekutusu@gmail.com> wrote:
Subject: Re: AW: AW: [Doepfer_a100] Let me hear your bright new ideas for future
Date: Saturday, November 1, 2008, 10:08 AM
Hi there!
Korhan
Hi Bakis,
Apologies if that's already been discussed. I am a bit behind the mass
of emails on this subject and may have missed it. I am glad that
someone else has already suggested it.
Korhan
> www. DiN. org. uk
> Athens - Greece
> From: Korhan Erel <listekutusu@gmail.com>
> ideas for future
> Hi there!
> Korhan
AW: AW: AW: [Doepfer_a100] Let me hear your bright new ideas for future
2008-11-03 by yahoo@doepfer.de
> available?
As mentioned on our website early in 2009. Currently we are about to find
out if the design can be used also as a quad VCO with 1V/octave and
sufficient temperature stability with some improvements (with additional
switch between VCLFO and VCO).
Best wishes
Dieter
RE: AW: AW: [Doepfer_a100] Let me hear your bright new ideas for future
2008-11-03 by David Salter
That is a nice idea, 4 VCO's on a module with a VCLFO option, good
proposition.
David Salter
Senior Consultant
SSG UKI
Thomson Reuters
O +44 (0)20 7542 2402X 52402
M 07990562402
david.salter@thomsonreuters.com
thomsonreuters.com <http://thomsonreuters.com/>
From: Doepfer_a100@yahoogroups.com [mailto:Doepfer_a100@yahoogroups.com]
On Behalf Of yahoo@doepfer.de
Sent: 03 November 2008 10:43
Subject: AW: AW: AW: [Doepfer_a100] Let me hear your bright new ideas
for future
be
> available?
find
Best wishes
Dieter
This email was sent to you by Thomson Reuters, the global news and information company.
Any views expressed in this message are those of the individual sender, except where the sender specifically states them to be the views of Thomson Reuters.
