You are right! That's why I use two A131s for this.. (for stereo)
On Tue, Nov 18, 2008 at 12:02 PM, vcfool <vcfool@gmail.com> wrote:
> > On Nov 17, 2008, at 8:18 PM, Doug wrote:
> > > I guess if you connect the same audio signal to both audio inputs, you
> > > would then have it coming out of the two outputs. Now vary the CV
> > > amount on each VCA and the audio could be made to increase on the left
> > > and diminish on the right, or vice versa. You need two LFO signals 180
> > > degrees out of phase (in other words, one inverted).
> Hi,
> When I use the A-132-1 for panning effects like this I also need to add an
> offset CV to both VCAs, to set the center volume level (when both the
> normal
> and inverted LFO=0V). Otherwise, when panning should be centered, you will
> have both VCAs completely muted instead.
> ...or you can use two VCAs that have an initial gain setting.
> Hope this helps,
> Jordi
> > > --- In Doepfer_a100@yahoogroups.com <Doepfer_a100%40yahoogroups.com><Doepfer_a100%
> 40yahoogroups.com>,
> > "techmaster242" <techmaster@...>
> > > wrote:
> > > > I've been talking with an established (signed) musician who uses a
> > > > modular, and he suggested getting an A-132 so I can make stereo
> > > sounds
> > > > with my modular. I've been giving some thought to his suggestion,
> > > and
> > > > I don't really see how that would work, seeing as it's two seperate
> > > > VCA's basically. I do see there is an A-134 VC Panning module, it
> > > > seems to make more sense to me, because you put a signal into it,
> > > then
> > > > you could modulate it with like an LFO, and have the sound going
> > > left
> > > > and right at an adjustable speed...or use ADSR to have it move
> > > around
> > > > in the stereo field as you play out notes...that would be especially
> > > > cool for pad type sounds. If you can do this with the A-132, how? Or
> > > > is the A-132 good for a different type of stereo effect?
> > [Non-text portions of this message have been removed]
