Frequency Shifter
2002-06-17 by code_pig
Here's one for the circuit heads... I'd really love to have a MUCH lower shift range (somewhere below 1Hz, as opposed to the standard 50Hz) on my A126. Any ideas? Thanks, Kevin
2002-06-20 by petergrenader
If somebody has a schemo to the Frequency Shifter I could probably figure this out how to decrease (lower) its range. I've done a bunch of mods to my Analogue Sys and Doepfer gear with great success!. I am seriously considering buying one of these shifters, would love to hear an audio test though to see if does what I need it to. So, if any of you out there are SO bored one night that you wouldn't mind doing this, I would greatly appreciate it: Using an ungated, steady signal: Sound of the unprocessed input signal (sine preferred) Sound of shift down output with no change of shift frequency of the Shifter itself. Sound of shift up output with no change of shift frequency of the Shifter itself. Sound of the Mix output of the same. All of the above again, this time with a steady gated signal (going trough a VCA controlled by a second or so decay only envelope (ramp out of an LFO would be perfect), One more sample, from either down or up output, having the frewuncy of the shifter controlled with some sort of triangle LFO signal. I undertsand this is an awful lot to ask. if any one obligies I would really appriecate it. Thanks, Peter --- In Doepfer_a100@y..., "code_pig" <code_pig@y...> wrote: > Here's one for the circuit heads... > > I'd really love to have a MUCH lower shift range (somewhere below > 1Hz, as opposed to the standard 50Hz) on my A126. Any ideas?
> > Thanks, > Kevin
2002-06-20 by code_pig
Peter, I don't have access to the schematic, but I'll rattle a cage or two, and see what I can find. Hey Bakis, do you have... ? As for the audio testing, I'll do it. Regards, Kevin --- In Doepfer_a100@y..., "petergrenader" <petergrenader@h...> wrote: > If somebody has a schemo to the Frequency Shifter I could > probably figure this out how to decrease (lower) its range. I've > done a bunch of mods to my Analogue Sys and Doepfer gear > with great success!. > > I am seriously considering buying one of these shifters, would > love to hear an audio test though to see if does what I need it to. > So, if any of you out there are SO bored one night that you > wouldn't mind doing this, I would greatly appreciate it: > > Using an ungated, steady signal: > > Sound of the unprocessed input signal (sine preferred) > > Sound of shift down output with no change of shift frequency of > the Shifter itself. > > Sound of shift up output with no change of shift frequency of the > Shifter itself. > > Sound of the Mix output of the same. > > All of the above again, this time with a steady gated signal (going > trough a VCA controlled by a second or so decay only envelope > (ramp out of an LFO would be perfect), > > One more sample, from either down or up output, having the > frewuncy of the shifter controlled with some sort of triangle LFO > signal. > > I undertsand this is an awful lot to ask. if any one obligies I would
> really appriecate it. > > Thanks, > > Peter > > > > > --- In Doepfer_a100@y..., "code_pig" <code_pig@y...> wrote: > > Here's one for the circuit heads... > > > > I'd really love to have a MUCH lower shift range (somewhere > below > > 1Hz, as opposed to the standard 50Hz) on my A126. Any > ideas? > > > > Thanks, > > Kevin
