Poll results for Doepfer_a100
2008-12-21 by Doepfer_a100@yahoogroups.com
The following Doepfer_a100 poll is now closed. Here are the final results: POLL QUESTION: Would you like Doepfer to release the module described below? I suggested the module idea to Dieter Doepfer and he suggested I make a poll to see what the community thinks. This poll might result in a new module! A voltage controlled patch matrix, 12x12 or larger, for routing signals without patch cables and a preset save option. The general idea would be similar to this product by Analogue Solutions: http://www.users.globalnet.co.uk/~concuss/ concussor/pp.htm But the Doepfer module would be smaller, more simple and less expensive, and built specifically to fit into the Doepfer framework. A number of modules would have their in- and outputs connected to the matrix's in- and outputs, and connections would be made internally without the need for patch cords being moved. It would be really interesting when one could save the matrix settings and recall them, instantly switching from one complex patch to another one. "Scrolling" through these presets could be voltage controlled by LFO's, sequencers, MIDI>CV, a joystick, etc. Especially for live use I think this would increase the possibilities of the A-100 immensely, as patch changes will become instantaneous. It would also have great waveshaping possibilities (audio rate patch switching?) If one had two or more of these vc audio routers, different parts of the signal path could be altered at different speeds by voltage control. So the module might have 12 inputs and 12 outputs (or 16, 24, ...) for signals and one or more cv inputs. CHOICES AND RESULTS - yes, it's a good idea, 128 votes, 67.02% - no, i don't need it, 40 votes, 20.94% - maybe, 23 votes, 12.04% For more information about this group, please visit http://groups.yahoo.com/group/Doepfer_a100 For help with Yahoo! Groups, please visit http://help.yahoo.com/l/us/yahoo/groups/original/members/web/index.html
