Doepfer
BBD module question
BBD module question
2008-12-27 by mm123 ah
heres a question about the doepfer bbd module function:
even without an incoming signal and with feedback set to zero, as i sweep clock time from minimum to maximum, i hear an audible oscillator that increased in pitch until around 12:00 position when im assuming its going above audio range.  i cant help but think this is a defect.  is something wrong or is this the way it was designed?  if its abnormal, any suggestions as to how to fix it?
thanks
mini
VINTAGE SYNTH DEALER
-We Buy, Sell & Trade Analog Synths
-Huge Selection, Years of Experience, Reliable Service
-Visit us at http://www.123synthland.com (redirects)
Send e-mail faster without improving your typing skills.
http://windowslive.com/online/hotmail?ocid=TXT_TAGLM_WL_hotmail_acq_speed_122008
Re: [Doepfer_a100] BBD module question
2008-12-27 by JOSHUA HOLLEY
What you're hearing is clock noise. This module needs an external filter to filter out that noise.
--- On Fri, 12/26/08, mm123 ah <mm123ah@hotmail.com> wrote:
> From: mm123 ah <mm123ah@hotmail.com>
> Subject: [Doepfer_a100] BBD module question
> To: doepfer_a100@yahoogroups.com, mm123ah@hotmail.com
> Date: Friday, December 26, 2008, 5:53 PM
> thanks
> mini
Re: BBD module question
2008-12-28 by Doug
I'm going to go out on a limb here and suggest that it may even be
desirable. Consider this for example at about 5:10-5:15
http://www.vimeo.com/1952077
> --- On Fri, 12/26/08, mm123 ah <mm123ah@...> wrote:
> > From: mm123 ah <mm123ah@...>
> > To: doepfer_a100@yahoogroups.com, mm123ah@...
> > thanks
> > mini
Re: [Doepfer_a100] Re: BBD module question
2008-12-28 by Bakis Sirros
of course it could be desirable!
[Doepfer_a100] group owner
www. parallel - worlds - music. com
www. myspace. com/ parallelworldsmusic
www. myspace. com/ interconnectedmusic
www. myspace. com/ memorygeist
www. DiN. org. uk
www. musicamaximamagnetica. com
www. shimarecords. co. uk
www. rubberrecords. gr
Athens - Greece
--- On Sun, 12/28/08, Doug <dougc356@yahoo.com> wrote:
Subject: [Doepfer_a100] Re: BBD module question
Date: Sunday, December 28, 2008, 8:10 AM
http://www.vimeo. com/1952077
> --- On Fri, 12/26/08, mm123 ah <mm123ah@... > wrote:
> > From: mm123 ah <mm123ah@... >
> > To: doepfer_a100@ yahoogroups. com, mm123ah@...
> > thanks
> > mini
> > -Visit us at http://www.123synth land.com (redirects)
> > ____________ _________ _________ _________ _________ _________ _
http://windowslive. com/online/ hotmail?ocid= TXT_TAGLM_ WL_hotmail_ acq_speed_ 122008
