tiptop audio question
2009-01-07 by michael901096
My rack is a Doepfer G6 set up to work in the uk. If at some point in the future i wanted to get modules from 3rd party manufacturers...particularly the z3000 smart vco /or z5000 processor- will they plug straight into my rack with the ribbon cable supplied by tiptop...or are there any alterations required?
--- In Doepfer_a100@yahoogroups.com, "michael901096" <doherty167@...> wrote: > > My rack is a Doepfer G6 set up to work in the uk. If at some point in > the future i wanted to get modules from 3rd party > manufacturers...particularly the z3000 smart vco /or z5000 processor- > will they plug straight into my rack with the ribbon cable supplied by > tiptop...or are there any alterations required? > Thanks for the info Mark.
2009-01-07 by Mark Pulver
Yeup... I have Tip-Top modules siting right next to Doepfer modules all on the same power bus. Mark ----- michael901096 (10:33 AM 1/7/2009) wrote:
>My rack is a Doepfer G6 set up to work in the uk. If at some point in >the future i wanted to get modules from 3rd party >manufacturers...particularly the z3000 smart vco /or z5000 processor- >will they plug straight into my rack with the ribbon cable supplied by >tiptop...or are there any alterations required?
--- In Doepfer_a100@yahoogroups.com, achtung_999 <heinrich.himmelwasser@...> wrote: > > Actually in 'eurorack land' it is only with Analogue Systems modules that > you need to do some alterations. > Greetings, > > Ernst > > Thanks Ernst > > > > On Wed, Jan 7, 2009 at 7:50 PM, michael901096 <doherty167@...>wrote: > > > --- In Doepfer_a100@yahoogroups.com <Doepfer_a100% 40yahoogroups.com>, > > "michael901096" <doherty167@> > > wrote: > > > > > > > > My rack is a Doepfer G6 set up to work in the uk. If at some point in > > > the future i wanted to get modules from 3rd party > > > manufacturers...particularly the z3000 smart vco /or z5000 processor- > > > will they plug straight into my rack with the ribbon cable supplied
> > by > > > tiptop...or are there any alterations required? > > > > > Thanks for the info Mark. > > > > > > > > > [Non-text portions of this message have been removed] >
--- In Doepfer_a100@yahoogroups.com, achtung_999 <heinrich.himmelwasser@...> wrote: > > Actually in 'eurorack land' it is only with Analogue Systems modules that > you need to do some alterations. > Greetings, > > Ernst > > Greetings Ernst, and thankyou also for the info Regards, Michael > > > > On Wed, Jan 7, 2009 at 7:50 PM, michael901096 <doherty167@...>wrote: > > > --- In Doepfer_a100@yahoogroups.com <Doepfer_a100% 40yahoogroups.com>, > > "michael901096" <doherty167@> > > wrote: > > > > > > > > My rack is a Doepfer G6 set up to work in the uk. If at some point in > > > the future i wanted to get modules from 3rd party > > > manufacturers...particularly the z3000 smart vco /or z5000 processor- > > > will they plug straight into my rack with the ribbon cable supplied
2009-01-07 by achtung_999
Actually in 'eurorack land' it is only with Analogue Systems modules that you need to do some alterations. Greetings, Ernst On Wed, Jan 7, 2009 at 7:50 PM, michael901096 <doherty167@btinternet.com>wrote: > --- In Doepfer_a100@yahoogroups.com <Doepfer_a100%40yahoogroups.com>, > "michael901096" <doherty167@...> > wrote: > > > > > My rack is a Doepfer G6 set up to work in the uk. If at some point in > > the future i wanted to get modules from 3rd party > > manufacturers...particularly the z3000 smart vco /or z5000 processor- > > will they plug straight into my rack with the ribbon cable supplied > by > > tiptop...or are there any alterations required? > > > Thanks for the info Mark. > > > [Non-text portions of this message have been removed]
