The RS-210 comb filter has a much shorter delay than even a 512 BBD
can do, there is a HUGE difference being that the doepfer BBDs are
much more versatile than the comb filter. The comb filter is a nice
module, but much less versatile. It's got a nice distinct sound to
me, but is not a BBD replacement. For Karplus stuff I use a 188-1
512stages and recently added the ASys Echo (I forget the model number
now). The 188-1 gives you more access to the BBD (like the clock a
second audio input, but overall, the ASys echo will probably slowly
replace the 188-1 as my main Karplus delay module since it is stereo
and I'm doing more stereo sythesis now. If you got the space, the
188-1 and the ASys Echo are great for wacking out sound. The Doepfer
BBDs are ok for delay, but very gritty, for clean delays I use the
ASys delay.
The Doepfer 132-3 (I think that's the number) is a very nice sounding
VCA that can be used for control signals as well since it's exp and
lin.
On Fri, Jan 9, 2009 at 8:19 AM, Ken <kenneth_harte@yahoo.co.uk> wrote:
> Hi all,
> I am in the process of putting together another 2 rack modular
> suitcase. I have one suitcase already and it's a well spec'd synth.
> plenty of osc's, env's, LFO's, mixer etc.
> I want to put together a second suitcase that I'll use for processing
> of external sounds. I was wondering if anybody had any suggestions.
> Also on a side note is the RS-120 (analogue systems comb filter)
> similar to a one of the A-188 modules? Is there a big difference
> between a comb filter and a BBD? I am not sure.
> Also I would like a good quality VCA. The Doepfer one I am using seems
> a bit noisy. Would anybody have a suggestion for a good quality VCA.
> thanks
> Ken
