Re: other waveforms?
2009-01-15 by zaum
> Not sure if there's anything euro format out there, but one module you > might look at is a Blacet Miniwave. There is a PlanB conversion kit > to make it work with the Doepfer power bus. > I'm not sure if there's anything else like it. Works as a wavetable > "oscillator", quantizer, and you can get some very interesting > modulations running an LFO through it. I'd second that the A-112 Sampler Wavetable has an interesting number of capabilities in comparison. Looking at other brands from an analog standpoint, the Livewire AFG is capable of numerous waveshapes and variations that don't even have names and even more are accessible through internal jumpers which I understand will be eventually controlled by an add-on module. Since the waves are the result of mixing and waveshaping internally, one great outcome is there is much to modulate. I think waveshape change through modulation opens up worlds more than simply having another shape to access. Then if you have linear FM inputs on one module and another VCO + a VCA to control FM input you have another modulation dimension to work in. Sync can be another with a second vco. Mark mentions MANY MANY VCOs, and that certainly doesn't hurt since you can summon more to build up dense sounds an more modulation. Sheer numbers do get you additive synthesis potential as well as more complex modulation. The practicality is you have to control them all and in many cases control them accurately to get best result. But as a basic premise there's no question that numbers of vcos mulitiply the number of timbres you can create. Historically it's sometimes amusing to see a few non-standard shapes early builders included. The EML 101 has 4 VCOs but only one of them has a saw wave available. You do get a cosine wave and some other odd but simple shapes. Early gear with a variable sine to some more complex shape is a direction Moog and his inspired by followers didn't go but is a very useful thing to have. EMS did something similar though with no CV control while Buchla did sines to nearly standard shapes with VC. > Primarily the interest is sonics. I am wondering if there is some > interesting possible sound that we don't really have easy access to > with subtractive synthesis. Or maybe just a cool shape that is some > way much different from the standards. Well there has to be plenty because the whole mid 80s to mid 90s digital era wouldn't have kicked out the analog gear if that weren't so ;-( I might add that it is kind of funny that after that so many "virtual" synths now simply give you some very basic analog subtractive synth simulation capabilities and stop there. But really, if you look at digital synthesis techniques you do find a lot of them that easily create sound spectra that are extremely difficult to duplicate with analog gear. You might need to answer how interesting to you these sounds are but you can crunch numbers to create waves you won't easily get when modulating the basic analog shapes. Another thing to consider is the visual nature of shape created by sonic spectra. It's well known that you can make very different looking shapes that have humanly indistinguishable timbres. So it's really about creating a sound that has an inspiring or contrasting harmonic and possibly inharmonic content. Nick
