Doepfer
Can A-111 VCO reset with its sync?
2009-01-17 by argitoth
If I plug a gate signal into the sync input of the A-111 VCO, will it
reset the VCO every time the gate goes on? With my Analogue Systems
VCO, a gate signal does not reset the VCO. Instead it makes the VCO
clicky and unusable. What I want to happen is that when there's a
Gate-on signal, the VCO simply resets and continues instead of
stopping like the Analogue Systems VCO.
Re: [Doepfer_a100] Can A-111 VCO reset with its sync?
2009-01-17 by Florian Anwander
Hi argitoth
The A110 and the A111 can be reset by a trigger to the sync-input.
The A110 expects a positive transition.
But the CEM3340-chip in the A111 expects a negative transition.
At both VCOs Dieter added a capacitor in series with to the sync in,
which will make a resetting trigger-spike from the start of the gate
and(!) from the end of the gate.
If you want to create drumsounds, you may provide extremely short gates.
If the gate is intended for a longer note (e.g bass sound), then the
best would be to get a gate to trigger converter, which produces a
trigger only from the start. You might send the gate to a A165 and then
combine the trigger-out with the gate in an AND-gate (A166). This
provides a trigger only at the start.
This should work also with te AS-VCO.
Florian
2009-01-17 by Argitoth
Florian, so with a few more modules I could actually make my Analogue
Systems VCO restart with a gate? I just need an A165 and A166? I don't
understand completely what you're trying to help me understand.
Re: Can A-111 VCO reset with its sync?
2009-01-18 by andreas
hi,
alternatively, the a142 vcd or the a162 trigger delay with zero delay
time should work, too. in both modules you can vary the gate length to
short triggers...
regards,
andreas
--- In Doepfer_a100@yahoogroups.com, Florian Anwander <fanwander@...>
wrote:
> Hi argitoth
> Florian
Re: [Doepfer_a100] Re: Can A-111 VCO reset with its sync?
2009-01-18 by Argitoth
Ok, I finally understand a little bit how to restart my AS-VCOs. I
took the square output of the A-146 LFO and when the square is
positive, the AS-VCO stops. Then the square goes negative, the AS-VCO
restarts. I then multiplied, inverted, and routed the A-146 to my
envelopes.
Here's the problem, and I think Florian and Andreas have the solution.
The problem is that the GATE output of my A-190 Midi-CV does not work
to reset the AS-VCO so I need to convert the GATE into something that
will work. The other problem is that when the square for the A-146
goes positive, the AS-VCO stops.
Florian says that a gate-to-trigger conversion will work. However, if
I ONLY have the A-162, will it be able to take a gate, turn it into a
trigger, and not cause the AS-VCO to stop?
2009-01-18 by Florian Anwander
Hello Argitoth
> restarts.
Yes: as long as the sync-in has a voltage at the input, the VCO stops
oscillating. In the end the hardsync is nothing else than an electonic
switch which shortens the capacitor that is the core of the oscillator.
As long as a voltage (and the gate is a voltage) is fed into the input,
as long the capacitor will be shortened. That is why I said: you need a
"spike".
I doubt, that the minimum duration (parameter "length") of the trigger
delay is short enough for a real not hearable reset. Still the waveform
will be flat for some 10th seconds. But ofcourse this is much better
than nothing. ;)
Florian
Two more questions, Florian. I need the shortest trigger possible. In
the manual it says, the A-165 creates a 50ms trigger. Is that the
shortest possible? And, can you tell me more about this spike that the
A-111 VCO creates when it resets? Does this spike create a nice
definitive attack?
On Sun, Jan 18, 2009 at 11:46 AM, Florian Anwander
<fanwander@mnet-online.de> wrote:
> Hello Argitoth
>> restarts.
> "spike".
> than nothing. ;)
> Florian
www.elanhickler.com
Hi Argitoth
> shortest possible?
the length is defined by the values of two parts (a capacitor and a
resistor). You might replace those parts, to get shorter triggers.
> definitive attack?
The A111 does NOT PRODUCE a spike(=extreme short trigger) but it
REQUIRES to RECEIVE a short spike(=extreme short trigger) at the
hardsync input. "Spike" may be the wrong word, but I am a poor german
boy and don't know any better.
Florian
2009-01-19 by Argitoth
Florian, I reread what you said and now I understand it better.
So I want an a-165 to convert a gate into a trigger spike. Does the
A-165 convert both the GATE ON and GATE OFF signals into trigger
spikes? So that's why I need an a-166 to make the A-165 only send out
a trigger spike on the GATE ON of the gate signal from my A-190 midi
interface?
2009-01-19 by Chris Henkel
...perhaps even easier to use for this purpose would be the AS MT-16
MIDI to trigger module?
...as it happens i still have two of them on offer:
http://tinyurl.com/9skpwm ;o)
2009/1/19 Argitoth <argitoth@gmail.com>:
> interface?
2009-01-19 by jalmari3
This doesn't help with Analogue Systems oscillators, but:
As I wrote in another forum, the Cwejman oscillators do not stop when
receiving a gate at their sync input. They just restart (get hard
synced) at the upward edge. Perhaps a short trigger is internally
generated to achieve this.
I was thinking about creating this for myself:
http://www.cgs.synth.net/modules/cgs24_gatetotrigger.html
www.elanhickler.com
AW: [Doepfer_a100] Re: Can A-111 VCO reset with its sync?
2009-01-20 by yahoo@doepfer.de
> interface?
Provided that you own an A-162 Dual Trigger Delay and are a bit experienced
with electronics e.g. the second unit of the A-162 can be modified very
easily for shorter trigger lenght. Finally each unit of the A-162 is nothing
but two daisy-chained gate-to-trigger converters with adjustable trigger
lengths. From the factory the time range is about 2 ms ... 10 s. But it can
be modified if C2 and/or C5 are replaced by smaller values. For details
please refer to the updated A-162 info page and the updated document "Timing
capacitors of A-100 modules" (www.doepfer.com > PRODUCTS > A-100 > DIY page
> Timing capacitors ...).
Best wishes
Dieter Doepfer
