thanks for the info. don't you just love babelfish. you should try
babelfish to translate japanese or korean. it beats the Comedy
channel in terms of sheer absurdity. could you imagine if William
Burroughs had access to babelfish? his writing and editing would be
even more cryptic and surreal. oh well, it would definitely help
Lindhof to have the site translated for the english modular netizens
of the interzone.;)
RM
Error in enemy strategy is switchboard redirected-
Word is TWO that is the noxious human inter language
recorded--And where you have TWO you have odor's
and nationalism's word--they started tampering with net
--Injury Headquarters blockade was broken--"Calling
partisans of all nations--Crab word falling--Virus photo
falling--Break through in Grey Room--"
Nova Express
William Burroughs, 1964
--- In Doepfer_a100@y..., "modularcharles" <ospengler@r...> wrote:
> A pass through the terrible Babelfish translator yields this
somewhat-
> intelligible translation:
> That modular Synthesizer
> D as modular Synthesizer system shown here is a complete music-
> electronic system for all kinds of music and sound production .
> E into good operational area for modular the system is also the
> employment as teaching material, for the representation of physical
> connections in instruction and in the training.
> One can to click oneself the information through on the desired
> module or by text left in the module overview indicate let.
> B egg the structure was paid attention to clearly defined
functional
> units and a well-thought-out arrangement of the control elements.
All
> modules cannot be exchanged among themselves, thus it restriction
of
> the combination and extension possibilities give. This was realized
> by a uniform first shot system, with which each module receives the
> necessary operating voltage over the system bus. In addition the
> control signals gate and CV of the modules are connected by the bus
> system.
> D IE inscription of the front plates is well legible and always
> informs about the function of the sockets, control knobs and LEDS.
> The modular system is developed in " 19 the format and can into
> everyone (Studio)Rack to be built. For the development of the
system
> simply zusatzliche module carriers can be used. The front plates
are
> aluminum colors and have standardized mass. As sockets 3,5 mm and
> 6,3mm klinkenbuchsen use find. For the sythesizerinterne linkages
> 3,5mm sockets are used and the 6,3mm sockets to come for the
> connection with the external world to the use. With some modules,
> which were conceived " as conditions " alone equipment, 3.5mm and
> 6.3mm sockets are present, in order to facilitate the integration
> into a studio. The switches and control knobs are mass-produced
> goods, which were selected exactly however under the Gesichspunkten
> of stability and quality. A very intensive operation can wear thus
> nothing to the equipment.
> B egg of the selection of the construction units for the control
> elements and the housing were used predominantly standardized mass-
> produced goods, in order to simplify an extending through own
> modules. A use of modules of other manufacturers in the modular
> system is easily possible by the use of an adapter plate.
> D IE electronics modular of the system is developed and on as small
> drift and a noise as possible was optimized only with handselected
> construction units. All entrances and exits are insensitive to
short-
> circuit. All modules are adjusted to the international standard of
> 1V/Oktave for control voltages and voltage levels from 0 to +10 V.
> The instrument is thus with all devices after this standard
> A lle developed and tested modules find them in the module
overview .
> B more ilder the Synthesizers of the idea " gives " it here up to
> now .
> D IE of modules in the planning phase or in the development phase
are
> at present are here separately specified. It is however possible
that
> no information stands to the modules for order.
> Modules in the development:
> Similar step sequencer
> --- In Doepfer_a100@y..., "ringmod45" <ringmod45@y...> wrote:
> > are these modules available right now? how limited are they? do
> they
> > fit in the doepfer case? do they use the same power voltage
> > requirements? anyone heard some of the limiters? the ssm might do
> the
> > trick,it would killer to have them in a rack instead of using
> > outboard gear. finally someone built simple limiters for a
modular.
> > the sequencers look different by looking at the switches. i wish
i
> > could read german, that way i would not have to ask all these
> > questions. if anyone could answer them, i would grateful. thanks.
> > RM
> > --- In Doepfer_a100@y..., "ethanzer0" <ethanzer0@y...> wrote:
> > > --- In Doepfer_a100@y..., "buechlerjoe" <buechlerjoe@t...>
wrote:
> > > > > Anybody heard of the LINDHOF MODULAR?
> > > > Search the archives, there was a bit of discussion between
> > Florian
> > > and
> > > > Paul a couple months back.
> > > > Joe
> > > Here is a picture of some of those modules
> > > http://www.msc175.de/synth/index.htm
> > > Ethan
