Doepfer
Ack. Worst day of my life...
2009-02-02 by madrayken
Along with my main PC, my A-100 refuses to work.
I've checked the mains socket and cable, and they are both fine.
However, when I plug in the A-100, I get nothing.
I've looked in the case, having removed all modules, and there's
nothing happening. No LEDs illuminating. Dead. I'm presuming that -
even with no modules plugged in - the A-100 case has LEDs that light
up in the case, yes? (It's been a long time since I turned it on
without modules in it).
Can anyone help me out with some suggestions?
Is there an obvious fuse for me to check out?
I'm going mad with worry that every one of my modules has been fried.
At this point, it's racking up as one of the worst days of my life.
Any help gratefully accepted.
Dene
Re: Ack. Worst day of my life...
Fuse found. It's blown. Thanks for the tip. I was looking around
*inside* the case for it like a fool.
Is it a 240v 5a fuse? Anyone got any recommendations on where to buy
one in the UK? All the 240v fuses I've found online are 'house fuses',
which I'm pretty sure are too big.
--- In Doepfer_a100@yahoogroups.com, Florian Anwander <fanwander@...>
wrote:
> Check the fuse. It is located in the socket for the power cable.
> Florian
> > Dene
> > Yahoo! Groups Links
Re: [Doepfer_a100] Ack. Worst day of my life...
2009-02-02 by Ross Stapf
Fuse.  Very Very likely.  Cheap and easy part to replace.
It happened to me about 6 months ago.
--- On Mon, 2/2/09, madrayken <dene.carter@gmail.com> wrote:
Subject: [Doepfer_a100] Ack. Worst day of my life...
Date: Monday, February 2, 2009, 9:21 AM
Dene
2009-02-02 by Florian Anwander
Florian
> Dene
Re: [Doepfer_a100] Re: Ack. Worst day of my life...
Hi madrayken
5 Ampere? never ;-)
Check: http://www.doepfer.de/faq/a100_faq.htm#Fuse
Florian
>> Florian
>>> Dene
>>> Yahoo! Groups Links
2009-02-02 by Sandy Brain
i'm pretty sure maplin would have one
> > Florian
> that -
> light
> fried.
> life.
> > > Dene
> > > Yahoo! Groups Links
2009-02-02 by Tim Stinchcombe
> one in the UK?
Most of my G6s are the older type, and I have had need of Maplin part
no. GL35Q in the past (these are 'T100' fuses). If you have the newer,
toroidal, power supply, then according to the link Florian supplied,
you are going to need GL55K, which is the 400mA rated one. If you have
anything other than a bog-standard G6, check that link *very* carefully!
Tim
My A-100 is the standard G6 case ordered from Thomann in Autumn last
year. I presume that means a 230V 400ma T (slow blow) fuse: the GL55K?
Piccy of the case is here:
http://www.denecarter.com/Beast.jpg
How would I find out which version it is, out of interest?
Dene
--- In Doepfer_a100@yahoogroups.com, "Tim Stinchcombe" <timothy@...>
> > one in the UK?
> Tim
2009-02-02 by dr_synthatron
This happened to me a while ago and after consulting the group
Florian pointed me in the direction of the fuse (thanks Florian). I
got some Time-lag 500mA fuses from Maplins (I'm in the UK too),
they're pretty cheap for a packet of ten but I've never had to
replace it since.
 --- In Doepfer_a100@yahoogroups.com, "madrayken" <dene.carter@...>
GL55K?
> Dene
> --- In Doepfer_a100@yahoogroups.com, "Tim Stinchcombe" <timothy@>
> > > one in the UK?
part
newer,
supplied,
have
carefully!
> > Tim
2009-02-02 by Sean Williams
If it's the older version it would have started spewing out HORRIBLE
stinking plumes of smoke from a melted mains smoothing capacitor by
now and leaked hideous brown gunk over the inside of the back panel!
Then you would have had to spend hours breaking open the mains inlet
and prizing away the fused and melted remains of the capacitor and
the plastic housing from rest of the inlet, being careful not to
crack and break the good bit of the housing, and then rewired the
connectors back. Not forgetting working out a way to clean the gunk
from the case while you're at it.
If none of that rings a bell then you probably have the new power supply.:)
><http://www.denecarter.com/Beast.jpg>http://www.denecarter.com/Beast.jpg
>Dene
>--- In
><mailto:Doepfer_a100%40yahoogroups.com>Doepfer_a100@yahoogroups.com,
>>  > one in the UK?
>>  Tim
2009-02-02 by Bakis Sirros
i have many older version G6's and never had any problem like the one you mention.
[Doepfer_a100] group owner
www. parallel - worlds - music. com
www. myspace. com/ parallelworldsmusic
www. myspace. com/ interconnectedmusic
www. myspace. com/ memorygeist
www. DiN. org. uk
www. musicamaximamagnetica. com
www. shimarecords. co. uk
www. rubberrecords. gr
Athens - Greece
--- On Mon, 2/2/09, Sean Williams <sean@artifactrecords.com> wrote:
Subject: Re: [Doepfer_a100] Re: Ack. Worst day of my life...
Date: Monday, February 2, 2009, 10:52 PM
><http://www.denecart er.com/Beast. jpg>http://www.denecart er.com/Beast. jpg
>Dene
>--- In
><mailto:Doepfer_ a100%40yahoogrou ps.com>Doepfer_a100@ yahoogroups. com,
>"Tim Stinchcombe" <timothy@... >
>>  > one in the UK?
>>  Tim
Yes I should think so. Take a peek at the PSU itself: about half way
down this page
http://www.doepfer.de/a100z_e.htm
you'll see the two types - the older A100NT12 has the 'strikethrough'
text; the newer A100PSU2 requires the higher-rated fuse, and is easily
recognised with the big round ('toroidal') transformer on it!
Tim
That problem actually relates to the IEC power inlet connector on the
backplate, rather than the power supply itself, and could possible
affect really old cases (like 10 years or so). I think these older
cases are identified by the on/off switch being separate from the inlet
connector itself; the filter in the inlet sometimes seems to go bad,
hence the horrid sticky brown goo it may exude. The filter wasn't
strictly necessary, and so later ones simply don't have it, and also
have the switch integral with the connector.
I bought a second-hand case exhibiting these symptoms - with care it is
possible to find a connector which is almost a 'drop in' replacement
(and considerably cheaper than a new one with the filter...
Tim
Bakis
If they are the first version G6 cases with the all-in-one switch and
IEC inlet then it's only a matter of time before those big caps fail.
Be warned! It's quite dramatic, but I don't think any real damage to
my modules occurred. To be fair, Dieter realized the problem ages ago
and changed the design, so you may have the old style PSU (650mA)
with the revised IEC inlet (without capacitor). If not, I hope you
have a well ventilated studio!
This happened to both my G6 racks in the same month last year - after
10 years of use. I wish I'd recorded the sound of the capacitor
fizzing and sputtering but I was too busy pulling the mains out  and
running out into the street with my Doepfer in my arms so as not to
set off the fire alarm!
sean
>down this page
><http://www.doepfer.de/a100z_e.htm>http://www.doepfer.de/a100z_e.htm
>Tim
my oldest G6 racks are from 2001, so, i hope that i do not have the oldest version...?
www. DiN. org. uk
Athens - Greece
Date: Tuesday, February 3, 2009, 12:43 AM
            Bakis
sean
>down this page
><http://www.doepfer. de/a100z_ e.htm>http://www.doepfer. de/a100z_ e.htm
>Tim
2009-02-03 by James Husted
And I hope this isn't going to happen to my portable cases!
-James
> oldest version...?
> www. DiN. org. uk
> Athens - Greece
> From: Sean Williams <sean@artifactrecords.com>
> Bakis
> sean
> last
> GL55K?
> >down this page
> e.htm
> easily
> >Tim
2009-02-03 by madrayken
Gotcha. Yup - mine's the big torus of coiled danger.
I've also just noticed that (much like the letters on the ring in Lord
of the Rings) there are tiny, near invisible letters on my dead fuse
telling me it's a 250v T 400mA fuse. Note to self: get better
illumination for room.
Fuses now ordered.
Thanks for the advice, folks. My day was just beginning to suck in an
unholy way.
> down this page
> Tim
2009-02-03 by dr_synthatron
I think the trouble with getting 400mA fuses is that they just keep
blowing which is why I got 500mA ones. I think it was Dieter who said
it was OK to use higher rated fuses.
Lord
> Fuses now ordered.
an
> unholy way.
last
GL55K?
way
> > down this page
the 'strikethrough'
easily
> > Tim
