Doepfer
Sound example: track with advanced A-154/155 sequencing
2009-03-04 by Florian Anwander
Hello,
in preparation for my live set last saturday I also recorded a track
which is built around a sequence from the A100 (finally the track didn't
make it into the set, but I think it is a nice example for the
A-154/A-155 and for the A-101-1 Steiner Parker filter.
basic patchsetup is:
A-111 saw into A-101-1 low pass in
A-110 pwm into A-101-1 band pass in (this one is faded in at 2:49)
A-142 is used as envelope. Triggered by a trigger from the first row of
switches at the A-155; the gate/decay-length is controlled by the
gate-out from the second row of switches at the A-155.
The envelope-out affects the filter cutoff and the pulsewidth of the A111.
The mode input of the A-154 is modulated by an triangle LFO. Since only
the positive half of the triangle does affect the mode modulation, the
Sequences runs in straight forward mode normally, but when the positive
half of the triangle is there the mode switches slowly through Backw.
Pend. and Rnd. So the Sequence gets very vivid.
This sound example at:
http://www.ambiosonics.de/session10/08_presession_Track3.mp3
The A100-patch can be seen at:
http://www.ambiosonics.de/session10/IMG_2050.JPG
The other takes of the session at:
http://www.ambiosonics.de/session10/index.html
(but without A-100 unfortunately)
Florian
Re: [Doepfer_a100] Sound example: track with advanced A-154/155 sequencing
2009-03-04 by Bakis Sirros
nice!
where are the drums from?
[Doepfer_a100] group owner
www. parallel - worlds - music. com
www. myspace. com/ parallelworldsmusic
www. myspace. com/ interconnectedmusic
www. myspace. com/ memorygeist
www. DiN. org. uk
www. musicamaximamagnetica. com
www. shimarecords. co. uk
www. rubberrecords. gr
Athens - Greece
--- On Wed, 3/4/09, Florian Anwander <fanwander@mnet-online.de> wrote:
> From: Florian Anwander <fanwander@mnet-online.de>
> Subject: [Doepfer_a100] Sound example: track with advanced A-154/155 sequencing
> To: Doepfer_a100@yahoogroups.com
> Date: Wednesday, March 4, 2009, 12:14 PM
> Hello,
> recorded a track
> track didn't
> the
> at 2:49)
> first row of
> by the
> LFO. Since only
> modulation, the
> the positive
> through Backw.
> Florian
Hi Bakis
> nice!
Xbase09 and TR808 (the latter partially through Alesis Bitrman).
The full mix runs also through a Alesis Smashup compressor in opto-mode,
which affects the drumsound too.
Florian
ok, thanks for the info.
best regards,
Bakis.
www. DiN. org. uk
Athens - Greece
Subject: Re: [Doepfer_a100] Sound example: track with advanced A-154/155 sequencing
Date: Wednesday, March 4, 2009, 12:30 PM
            Hi Bakis
>> http://www.ambioson ics.de/session10 /08_presession_ Track3.mp3
> nice!
Florian
