Doepfer
A174 spring removal - does the Joystick stay still?
2009-03-06 by mirror_saw7778
I just got a A174 and was wondering if I remove one or both of the springs will the joystick have enough resistance to stay put after I let go of it? My modular is on a vertical +25 degree angle. I also noticed that the X and Y axis are different mechanically - would one be better to remove the spring from? By better I mean would it stay in place on its own if not touched?
Re: [Doepfer_a100] A174 spring removal - does the Joystick stay still?
2009-03-06 by Monroe Eskew
experiment...
> touched?
2009-03-06 by Sean Williams
>experiment...
Isn't that a bit risky since it's a one-way mod?
>>  touched?
2009-03-06 by ybl@yahoo.com
Yes it does
Sent via BlackBerry
Date: Fri, 06 Mar 2009 01:05:31
To: <Doepfer_a100@yahoogroups.com>
Subject: [Doepfer_a100] A174 spring removal - does the Joystick stay still?
