Doepfer
potentiometer source
2009-03-22 by waynerdlance
Hello. Does anyone one where to find the pots used on most the doepfer modules. Im looking for some that have the same spacing(almost like for a guitar body) which is about 1/2" of thread and with the pcb supports. They say DI YA on the backs and i haven't found such a manufacturer. Any help would be appreciated.
Thanks Lance
Re: [Doepfer_a100] potentiometer source
2009-03-23 by Monroe Eskew
I think the ones from Parts Express are the same size.  partsexpress.com
> Thanks Lance
2009-03-23 by lance iden
I just looked at those and there are solder lug termination and they dont
have the pcb supports. also the thread is probably only a 1/4". Thanks for
the reply.
Lance
> On Sun, Mar 22, 2009 at 6:27 PM, waynerdlance <lance.iden@gmail.com<lance.iden%40gmail.com>>
> They
> > Thanks Lance
AW: [Doepfer_a100] potentiometer source
2009-03-23 by yahoo@doepfer.de
> Thanks Lance
The pots used in the A-100 are custom made devices (e.g. special lenght of
the thread and shaft) and are not available as standard products (we have to
order at least 10000 pots per order, otherwise the manufacturer does accept
the order). But you can get them from your local Doepfer representative as
spare parts.
Best wishes
Dieter Doepfer
Re: potentiometer source
2009-03-23 by Tim Stinchcombe
Here they are:
http://www.diya.com.tw/indexe.htm
...but note Dieter's comment about minimum order!
Tim
Re: [Doepfer_a100] Re: potentiometer source
Thanks for the replies. Im pretty sure i'll never need that many pots. At
least i dont think.
Thanks Lance
On Mon, Mar 23, 2009 at 12:38 PM, Tim Stinchcombe <
> Here they are:
> Tim
AW: [Doepfer_a100] Doepfer is turning to the Dark Side ?
2009-03-24 by yahoo@doepfer.de
That's nothing but a standalone version of the A-111-5 with vintage type
knobs. The unit is built into a black metal case with power supply and
Midi/USB interface. And the distance between the controls is more than in
the A-100 because of the larger knobs.
Details can be found in the press release on our website that was published
today: www.doepfer.com > PRESS
Best wishes
Dieter Doepfer
> -----Ursprungliche Nachricht-----
> [mailto:Doepfer_a100@yahoogroups.com]Im Auftrag von Guy Drieghe D.
> Gesendet: Montag, 23. Marz 2009 22:53
> Betreff: [Doepfer_a100] Doepfer is turning to the Dark Side ?
> http://www.gearjunkies.com/news_info.php?news_id=3665
> Nice !
> w/ Moog style knobs ?
> _g
Re: Doepfer is turning to the Dark Side ?
2009-03-24 by rcf_vvvv
The Dark Energy synth looks great ... but where is the slew/glide control?
I do like the idea of building a micro modular out of the A111-5, and 3-4 other modules. Maybe 50HP wide with a strip underneath for the A115 pin breakouts (Inverter In/Out, LFO & ADSR out), plus a multiple and a couple attenuators.
What would really excite me is if a very small system like this could be battery powered. The twin sealed lead acid battery solution, adopted by some here, sounds like it works well. However, something running of one compact Li-ion power pack would take up much less room in such a small case. I haven't built a Doepfer system yet, but I am tempted by this possibility!
rcf
> Best wishes
> Dieter Doepfer
> > Nice !
> > _g
Re: [Doepfer_a100] Re: Doepfer is turning to the Dark Side ?
2009-03-25 by Richard Scott
You really should put quarter inch jacks on that thing - mini jacks don't any sense for a standalone.: especially for the audio i/o Then all those moogerfooger owners will just have to buy one too! Moog should made something like this a long time ago
I agree on the missing lag generator I also wonder if there is any way one of the LFOs could be used as a simple EG? Its nice having two LFOs but with a single EG its difficult to see it is as complete monosynth. - an extra simple EG which was loopable and could double as an LFO might be better?
Richard
  Sent: Tuesday, March 24, 2009 7:34 PM
  Subject: [Doepfer_a100] Re: Doepfer is turning to the Dark Side ?
  rcf
  > Best wishes
  > Dieter Doepfer
  > > Nice !
  > > _g
