Doepfer
FW: Will Doepfer ever release the EMS filter - Unlikely read below
2002-07-10 by David Salter
David Salter
Reuters Consulting
Tel: +44 20 7542 2402
Mob: +44 7990562402
Fax: +44 20 7542 2699
>  -----Original Message-----
> From: 	David Salter
> Sent:	10 July 2002 14:06
> To:	Doepfer User Group (doepfer_a100@yahoogroups.com)
> Subject:	Will Doepfer ever release the EMS filter - Unlikely read below
> Analogue systems/EMS collaboration
> Analogue systems are pleased to announce the successful negotiations with legendary U.K synth manufacturer EMS a licensing agreement to produce certain classic modules to compliment the integrator range.
> These modules will bear the EMS name and will faithfully reproduce the circuitry of the EMS VCS3 and synthi a.
> The modules will incorporate all the modifications and updates that EMS undertook over the years with EMS allowing full access to the schematics and files to analogue systems designers.
> The first modules will be EMS synthi filter which will incorporate the 18db/24db toggle switch which represents pre 1974/post 1974 changes so the user can decide from what era he wants the filter to emulate. voltage controlled resonance will be available because this was incorporated on the circuit boards but mot implemented on the synth itself.
> The next module to be manufactured will be the a on d off trapezoid envelope generator again with all the official mods to stabilise the circuit to increase its usefulness.
> If these first two modules are successful then there is a possibility of the two companies working on a joint project to create the super synthi with separate signal and control matrices, dual joystick controllers ,midi etc.
> The first module should be available by September.
> This was take from Analogue Systems website www.analoguesystems.com
> David Salter
> Reuters Consulting
> Mob: +44 7990562402
        Visit our Internet site at http://www.reuters.com
Any views expressed in this message are those of  the  individual
sender,  except  where  the sender specifically states them to be
the views of Reuters Ltd.
Re: FW: Will Doepfer ever release the EMS filter - Unlikely read below
2002-07-10 by buechlerjoe
Interesting. First EMS tries to price-gouge Doepfer for licensing the
EMS filter. Then Dieter decides to drop the deal and produce a
modified diode filter without EMS participation. Then EMS realizes
they've screwed up an opportunity to make some money, and does a deal
with AS instead.
Maybe now that Big Briar has regained the rights to the Moog name, we
should have some Doepfer "Signature Series" Moog modules for the A-100
(Starting with the filter, of course).
Joe
2002-07-11 by buechlerjoe
A-102. See the "Future Modules" page on the Doepfer web site.
bakis, I believe, has a prototype version of this module for test.
Joe
> which filter is this?
> -pH
Re: [Doepfer_a100] Re: FW: Will Doepfer ever release the EMS filter - Unlikely read below
2002-07-11 by bakis Sirros
hi joe and list,
nope...i have a very early prototype that sounds quite
different from the a102 that will go into production.
bakis.
> web site.
> module for test.
> Joe
> a
> > -pH
synthfreak(parallel worlds)
athens-greece
[Doepfer_a100] group owner-moderator
Do You Yahoo!?
Sign up for SBC Yahoo! Dial - First Month Free
http://sbc.yahoo.com
