Doepfer
Re: A-138e (was: A-111-2 Dynamic VCO)
2009-03-26 by scistudio440
I believe you are right with the A-144+A-135 idea.
But what do you mean by adapt the A-138e for use with the A-101-9 ?
--- In Doepfer_a100@yahoogroups.com, zaum <zaum@...> wrote:
>  > Interesting this A-138e module. However can you control those
> knobs with CV ?
> You can't, the same with the EML-101, no CV either.
> For CV I think you need the A-144 + A-135.
> I wonder if the A-138e can be easily adapted for use with the A-101-9
> Vactrol module?
2009-03-26 by zaum
knobs with CV ?
Vactrol module?
2009-03-27 by nicholas_kent
The A-101-9 provides variable resistance controlled by CV. In some but not all cases it can provide the variable resistance an existing pot does, only put what the pot controls under CV control. I'm sure the manual describes it better.
AW: [Doepfer_a100] A-138e (was: A-111-2 Dynamic VCO)
2009-03-27 by yahoo@doepfer.de
> Vactrol module?
The A-101-9 can be used only to replace a simple resistor. The A-138e uses
custom made potentiometers with additional center tap. It's not possible (at
least not in an easy way) to use the A-101-9 to make a voltage controlled
version of the A-138e.
Best wishes
Dieter Doepfer
