Doepfer
Re: [Doepfer_a100] Re: A-183-2 Please say it's true
2009-03-29 by Bakis Sirros
0 to +1 or 0 to -1 amplification range would mean actually no amplification at all, only attenuation and inverted scaling...
my opinion is that the module is fine as it is, for what it is supposed to do.
[Doepfer_a100] group owner
www. parallel - worlds - music. com
www. myspace. com/ parallelworldsmusic
www. myspace. com/ interconnectedmusic
www. myspace. com/ memorygeist
www. DiN. org. uk
www. musicamaximamagnetica. com
www. shimarecords. co. uk
www. rubberrecords. gr
Athens - Greece
--- On Sun, 3/29/09, jalmari3 <jari.jokinen@netikka.fi> wrote:
Subject: [Doepfer_a100] Re: A-183-2 Please say it's true
Date: Sunday, March 29, 2009, 12:09 PM
            Maybe too late, but
Wouldn't the A-183-2 be more valuable, if it had simple mixer function too? There is room (at least if omitting the second output) for a unity gain input.
Since I have A-133, I would prefer 0...+1 and -1...+1 amplification ranges instead of 0...+2 and -2...+2.
--- In Doepfer_a100@ yahoogroups. com, <yahoo@...> wrote:
> > Okay so is the A-183-2 really be coming out in a month or so, or has
> > it changed?
> So far we have no release date for the A-138m (Matrix Mixer), A-183-1 (Dual
> Attenuator) and A-183-2 (Offset Generator/Attenuato r/Polarizer) . Custom made
> potentiometers will be used in these modules and we are still waiting for
> the samples of the manufacturer. As soon as the samples arrive we will test
> them and if they are OK I expect that the modules will be available ~ April.
> If the potentiometer samples will not fit the release date has to be
> postponed
> > 2) Will it possibly be able to handle audio so that I can use it to
> > amplify audio with gain>1?
> yes (max. 2), for other max. amplifications the module has to be modified
> (changing the value of a resistor)
> Best wishes
> Dieter Doepfer
2009-03-29 by jalmari3
Maybe 0V...2 and -2...+2 amplification range suits most users. Still, second input with unity gain seems good use of panel space to me. Similar function as in Serge Scaling Processor module.
--- In Doepfer_a100@yahoogroups.com, Bakis Sirros <synth_freak_2000@...> wrote:
> www. DiN. org. uk
> Athens - Greece
> --- On Sun, 3/29/09, jalmari3 <jari.jokinen@...> wrote:
> From: jalmari3 <jari.jokinen@...>
>             Maybe too late, but
> > > it changed?
> > postponed
> > Best wishes
> > Dieter Doepfer
