Doepfer
a171: another slew problem
2009-05-17 by Stu Grimshaw
hi group,
i get a drop in pitch when i reduce the slew rate from maximum on an a171 slew limiter connected dirctly to a single vco.
is there a simple fix as there is with the a170?
i'd appreciate any help.
cheers,
stu
Re: a171: another slew problem
2009-05-17 by Tim Stinchcombe
Hi Stu,
Yeah, sounds like it could be the same problem as before - the output protection resistor, though in the A-171's case it is already lower (at 220ohm) than the 1k in the A-170. So, you could try shorting it, or putting a 100ohm across it to reduce the value, and see if that helps (but heeding Dieter's warning in message #15764!).
Assuming your module is the same as mine (it uses a CA3080, so presumably will need a re-design to use an LM13700 at some point...), it is the red-red-brown resistor on the left of the three between the two chips (i.e. nearest the bigger chip - I can't make out its actual 'R' number).
Tim
--- In Doepfer_a100@yahoogroups.com, "Stu Grimshaw" <grimshaw@...> wrote:
> hi group,
> cheers,
> stu
Re: [Doepfer_a100] a171: another slew problem
2009-05-17 by Sean Williams
If I remember right, there is an offset trimpot
on the A171, but it should also be OK to do the
same mod as on the A170. I used a 60‡ resistor on
the A170 and it tracks pitch fine now.
sean
>hi group,
>cheers,
>stu
