Doepfer
A-143-1 Attack Modification (C1 Capacitor)
2009-05-24 by j_inform3r
I just searched the list and found no posts regarding this modification. I purchased this module when it first came out and I thought it was great, except that the attack time was a wee bit too slow. I was surprised when I found on the Doepfer site a page which shows a way to mod the Attack/Decay time by changing one capacitor value. Here's the page:
http://www.doepfer.de/DIY/a100_capacitors.htm
It says that the timing capacitor (C1) is a 2.2 microfarad, corresponds to about 5ms shortest attack/decay time. Does "shortest attack/decay time" mean that it can't get any quicker? What if I lower the value of the cap? I wanted to ask if anyone has done this and what value did they use. I'm really hoping that it's possible to make the attack a bit more snappy (like 1ms) because the module is great but the attack time is too slow for my personal use. I'd love to hear any responses regarding this.
John
Re: [Doepfer_a100] A-143-1 Attack Modification (C1 Capacitor)
2009-05-24 by Andreas- theCovertOperators.Org
Once again the MuffWiggler forum is THE place online for modular knowledge!
http://www.muffwiggler.com/forum/viewtopic.php?p=23126#23126
- the mod is way easy, John, you should totally do it. Oh, and sign up
at the forum there and share your progress!
Best,
Andreas
> Regards,
> John
2009-05-25 by Florian Anwander
Hello John,
This means: the shortest attack/decaytime is 5ms if you use a 2.2uF
capacitor. If you use a smaller value for this capacitor, then you get
shorter minimal envelope times.
btw: I once had the A-143-1 and to my estimation, the minimal attack
time was longer(!) than 5 ms. But this can depend on the allowed
varation of the true values of the different parts against the nominal
values. Resistors can vary 5% or 10%, capacitors 20%.
Florian
Re: A-143-1 Attack Modification (C1 Capacitor)
2009-05-25 by j_inform3r
Hi Andreas et al,
    I've seen the MuffWiggler thread you posted. Unfortunately it only deals with extending AD time. The opposite of my goal.
    Since Dieter is out of the office for a while I sent my question to another address at Doepfer. They replied and said that I CAN decrease the attack time by lowering the value of C1 but I will also be lowering the decay time. So now I'm wondering if it will be possible to get the attack around 1ms without ruining the decay time. Anyone know what the "stock" decay time is? I don't require super looooong decay's. Basically, I'm wondering what the proportion is between; attack time/decay time. Has anyone made their A-143-1 snappier? What basis should I go by to figure this out (value of C1) to get 1ms attack time?
    John
--- In Doepfer_a100@yahoogroups.com, "Andreas- theCovertOperators.Org" <a@...> wrote:
> Best,
> Andreas
> > Regards,
> > John
2009-05-25 by tony.steventon.t21@btinternet.com
Hi John
The basic principal behind timing circuits is that the capacitance is proportional to the time constant.  So if you have a circuit with 2.2uF and it gives 5ms AD time then 0.44uF (i.e. a fifth of 2.2uF) will give about 1ms.  The nearest preferred value to this is 0.47uF or 0.39uF.
The delay time will also be reduced to about a fifth of what it was. It is worth experimenting and you can always go back to the original component.  Hope this helps.
Tony
--- In Doepfer_a100@yahoogroups.com, "j_inform3r" <abstract.express@...> wrote:
>     Hi Andreas et al,
>     Thanks,
>     John
> > Best,
> > Andreas
> > > Regards,
> > > John
AW: [Doepfer_a100] Re: A-143-1 Attack Modification (C1 Capacitor)
2009-06-02 by yahoo@doepfer.de
>     Hi Andreas et al,
Sorry - that's not possible because the same capacitor is used for both
attack and decay.
Best wishes
Dieter Doepfer
Re: AW: [Doepfer_a100] Re: A-143-1 Attack Modification (C1 Capacitor)
2009-06-02 by Richard Scott
the A-183-3 amplifier looks like a useful utility module Dieter. I'm
often wishing I had something simple like that onboard - In practise
whether x4 is really enough for audio I'm not sure... maybe
Richard
yahoo@doepfer.de wrote:
>  > Hi Andreas et al,
> attack and decay.
> Best wishes
> Dieter Doepfer
I am using the free version of SPAMfighter.
We are a community of 6 million users fighting spam.
SPAMfighter has removed 1190 of my spam emails to date.
Get the free SPAMfighter here: http://www.spamfighter.com/len
The Professional version does not have this message
2009-06-02 by Florian Anwander
Hi John, hi Dieter,
Not completely a separation of the two time rates, but some
approximation (this assumes, that the potentionmeters are not used as
electrical potentiometers, but as variable resistors):
- Reduce the Capacitor
- Insert a fixed resistor (lets say 20% of the potentiometer value) on
the maximum side of the attack potentiometer
-Insert a fixed resistor (at least the same value as the R above or even
more) on the minimum side of the decay potentiometer.
This will cause shorter attack times, and will keep the minimum Decay
time where it is. If the addition decay-resistor is even larger than the
attack-resistor, then the decaytime will stay the same as with the
original capacitor.
Florian
yahoo@doepfer.de schrieb:
>>     Hi Andreas et al,
> attack and decay.
> Best wishes
> Dieter Doepfer
AW: AW: [Doepfer_a100] Re: A-143-1 Attack Modification (C1 Capacitor)
> Richard
Within the A-100 or connected to other modular systems x4 should be
sufficient because the output signal has to be within about -10.5V....+10.5V
because of the +/-12V power supply (you cannot obtain an output voltage that
is higher than the supply voltage and in adddition there is some voltage
drop in the operational amplifiers). This means that any voltage in the
range -2.5...+2.5V can be amplified before clipping occurs. If you want a
higher amplification the module can be modified (changing the value of a
resistor for the ranges x2 and x4).
Best wishes
Dieter Doepfer
> Hi John, hi Dieter,
> original capacitor.
> Florian
These serial resistors are already available in the circuit. Both the attack
and the decay circuit use a 1M variable resistor in series with a 2k2 fixed
resistor (so the minimum overall resistance is 2k2 when the potentiometer is
fully CCW). The fixed resistors are R4 (attack) and R5 (decay). R2 is
located just behind the attack potentiometer, R5 near C1 (next to the 555
timer circuit). One could replace C1 e.g. by 0.22n (i.e. 1/10 of 2u2) or
0.47n (i.e. 1/5 of 2u2) and increase R5 to 22k (x10) or 10k (x5). It's not
possible to insert a fixed resistor to the "maximum" side because it does
not matter if the fixed resistor is added to the max or min side because
both resistance values (fixed + potentiometer) are always added.
Best wishes
Dieter Doepfer
Re: AW: AW: [Doepfer_a100] Re: A-143-1 Attack Modification (C1 Capacitor)
Hi Dieter
> It's not
You misunderstood me. It definitely does matter. But I am leaving now,
so I will post tomorrowmy explanation.
Florian
2009-06-03 by Florian Anwander
Ok
After some sleep and cleaning the head from inside :), I see that Dieter
is right. It does not matter, where the resistor would be positioned.
So the corrected description would be as Dieter wrote it:
- Reduce the Capacitor C1. This will cause the attack times to be
shorter. The decay times would be shorter too, but we will...
- ...increase the Resistor R5 of the decay potentiometer. This will
"compensate" the smaller capacitor value: the decay behaviour will be
quite the same as before.
Sorry for the confusion.
Florian
Florian Anwander schrieb:
> Hi Dieter
>> It's not
> Florian
