Doepfer
a124 wasp filter input level
2009-05-27 by floris vanhoof
i'm feeding the wasp filter with a silent sound source, is there a way to make the volume higher than the maximum of the level knob?
i have an external input module with a gain knob, but not in this tiny case i use live.
can i get the gain higher just by modifying the wasp filter module a little?
Re: [Doepfer_a100] a124 wasp filter input level
2009-05-27 by achtung_999
Isn't it an idea to not use the 'silent sound source'.
And start using a sound source that is non-silent?
All joking aside: I don't understand your question.
On Wed, May 27, 2009 at 5:01 PM, floris vanhoof
> i use live.
Re: a124 wasp filter input level
the sounds that go in are less loud than normal doepfer vco's or noise sources, would it be possible to have those sounds as loud as the vco's etc by modding the filter module?
--- In Doepfer_a100@yahoogroups.com, achtung_999 <heinrich.himmelwasser@...> wrote:
> > i use live.
Re: [Doepfer_a100] Re: a124 wasp filter input level
Ah, now I understand.
I think Dieter can answer that question better than I can. But I guess
it is possible.
On Thu, May 28, 2009 at 12:24 AM, floris vanhoof
>> > to
>> > case
>> > i use live.
>> > little?
RE: [Doepfer_a100] Re: a124 wasp filter input level
2009-05-28 by david.salter@thomsonreuters.com
Would it not be better to amplify the source?
David Salter
Senior Consultant
SSG UKI
Thomson Reuters
O +44 (0)20 7542 2402X 52402
M 07990562402
thomsonreuters.com <http://thomsonreuters.com/>
P Please consider the environment before printing this e-mail
From: Doepfer_a100@yahoogroups.com [mailto:Doepfer_a100@yahoogroups.com]
On Behalf Of floris vanhoof
Sent: 27 May 2009 23:25
Subject: [Doepfer_a100] Re: a124 wasp filter input level
<mailto:Doepfer_a100%40yahoogroups.com> , achtung_999
way to
tiny case
> > i use live.
little?
This email was sent to you by Thomson Reuters, the global news and information company.
Any views expressed in this message are those of the individual sender, except where the sender specifically states them to be the views of Thomson Reuters.
2009-05-28 by Silas Frederik Johansen
That is exactly what you do if you increase the gain of the module. It's
possible on the A-120 ladder filter by soldering in an extra resistor - very
simple mod - but I don't know if the same is true for the Wasp filter.
/Silas
> David Salter
> Senior Consultant
> SSG UKI
> Thomson Reuters
> M 07990562402
> david.salter@thomsonreuters.com <david.salter%40thomsonreuters.com>
> From: Doepfer_a100@yahoogroups.com <Doepfer_a100%40yahoogroups.com>[mailto:
> Doepfer_a100@yahoogroups.com <Doepfer_a100%40yahoogroups.com>]
> To: Doepfer_a100@yahoogroups.com <Doepfer_a100%40yahoogroups.com>
> --- In Doepfer_a100@yahoogroups.com <Doepfer_a100%40yahoogroups.com>
> <mailto:Doepfer_a100%40yahoogroups.com <Doepfer_a100%2540yahoogroups.com>>
> , achtung_999
> way to
> tiny case
> > > i use live.
> little?
> Reuters.
2009-05-29 by Tim Stinchcombe
Hi Floris,
There is a 27k resistor immediately after the audio in 'level' pot (between the pot and capacitor C1, but easy to find by following the trace from the pot wiper). If you lower this that should increase the gain, but (and I'm guessing here) I don't suppose you'll get much more than 2x or 3x improvement out of it before it goes 'haywire' (I could be wrong!). I suggest trying an 18k first, see what effect that has, and if that's OK, perhaps try a 10k - lower than that and it's anybody's guess! (Because the filter uses digital inverters as amplifiers, these are 'biased' by a variety of resistors, and lowering this one may have an effect on this biasing which stops the whole thing working properly, but without trying it, I can't be sure!)
Tim
2009-05-31 by floris vanhoof
thanks! i'll try it this week.
+i can hear my a-146 lfo thinking and beeping through my filter, not super loud, but annoying anyway. anyone else has a problem like this? how can one solve it? is it the diy power supply?
--- In Doepfer_a100@yahoogroups.com, "Tim Stinchcombe" <timothy@...> wrote:
> Hi Floris,
> Tim
AW: [Doepfer_a100] a124 wasp filter input level
2009-06-02 by yahoo@doepfer.de
> module a little?
Please look at the A-100 DIY page, section 4.1.1. Changing the sensitivity
of manual controls, control voltage inputs and audio inputs
For A-124 it's R1 (27k) located just behind the potentiometer for audio
level control. If you reduce the value (factory 27k) of this resistor the
max. loudness increases. Another solution will be the usage of the planned
A-183-3 amplifier module.
Best wishes
Dieter Doepfer
AW: [Doepfer_a100] Re: a124 wasp filter input level
> Hi Floris,
> Tim
Couldn't explain it better :-)
Best wishes
Dieter Doepfer
