Doepfer
Re: [Doepfer_a100] Ground loop hum?
2009-06-14 by Bakis Sirros
yes, it happens with my laptop too, even if i have the audio interface powers from its own psu...
so, when i want to record audio in the laptop,  i just unplug the laptop from the mains and power it from its battery....
[Doepfer_a100] group owner
www. parallel - worlds - music. com
www. myspace. com/ parallelworldsmusic
www. myspace. com/ interconnectedmusic
www. myspace. com/ memorygeist
www. DiN. org. uk
www. musicamaximamagnetica. com
www. shimarecords. co. uk
www. rubberrecords. gr
Athens - Greece
--- On Sun, 6/14/09, Florian Anwander <fanwander@mnet-online.de> wrote:
Subject: Re: [Doepfer_a100] Ground loop hum?
Date: Sunday, June 14, 2009, 3:08 PM
      Hi Peter
> If I plug headphones directly into a module's output then I don't hear it. When I plug the module's output into my audio interface, then I get the noise/hum. This is what leads me to believe it's a ground loop. Am I correct? If so, how do I remove it safely? A DI box with a ground lift feature?
I assume it is an interface, which is powered via the datacable from the
computer. If i am right, then the solution will be either powering the
interface via an separate powersupply, or connect the Doepfer to the
computers interface via an passive DI split box (means ot
electronically, but true split with a transformer) .
This problem happens very often with computers with separated LCD
monitors (e.g. at our sessions it happes to two persons with Apple
MacMini plus monitor), but also sometimes with laptops.
Florian
2009-06-14 by PETER MARSHALL
The audio interface has it's own power supply and is connected to my laptop via firewire.
Unfortunately my laptop's battery has died so I always have it plugged into the mains supply too.
On top of that, I have two monitors that are both connected to the mains & to the audio interface's main outputs.
So, I guess I'll try a DI box. Can you recommend any?
Thanks for your help guys!
Pete
2009-06-14 by Florian Anwander
Hello Peter,
it depends on the quality requirements. Jensen are the best, Millenium
from Thomann the cheapest, but ok for the amateur recordings.
Florian
> Pete
2009-06-14 by achtung_999
Bss Active DI boxes are extremely reliable. But maybe a bit too pricey.
On Sun, Jun 14, 2009 at 7:52 PM, Florian
Anwander<fanwander@mnet-online.de> wrote:
> Hello Peter,
> Florian
>> Pete
2009-06-15 by Florian Anwander
Hi
He definitely needs a PASSIVE split box.
Florian
2009-06-15 by PETER MARSHALL
Hi guys,
Just to let you know, I eventually went for an ART DTI passive dual tranformer / isolator, and it works just fine.
Thanks for the help, much appreciated!
Pete
Sent: Monday, 15 June, 2009 6:07:57 PM
Hi
Florian
2009-06-15 by achtung_999
ah yeah..
I was reading to quick. Soooooooorry!
On Mon, Jun 15, 2009 at 7:07 PM, Florian
> Hi
> Florian
